Message 1 of 1
ReCap 2026.1 Beta Participation
We'd like to request your participation in testing ReCap Pro 2026.1 Beta.
To do so:
- Go to https://feedback.autodesk.com/
- Under Opportunities, look for "Autodesk Infrastructure Futures"
- Click View Opportunity and apply for access
- After access is granted, click on "Autodesk Infrastructure Futures" tab menu
- Click on "ReCap Builds"
- Click on "ReCap Pro 2026.1 Beta"
- The instructions, release notes, and help doc are attached to the page.
Key Features:
ReCap Pro:
- Added support for loading either the Mesh (generated using scan to mesh local) or the Point Cloud from the recent projects dashboard.
- Added status icons for project thumbnails in the recent projects dashboard to indicate if the mesh and/or point cloud exists.
- Added support for importing E57 files with panoramic images captured using Riegl scanners.
- Added new E57 image import options for resolution mismatch between panoramic images and scans.
- Added new DeCap commands for resolution mismatch options for E57 files.
- Added support for running multiple instances of ReCap Pro.
- Added support for exporting each classification individually similar to exporting regions.
- Added support for deleting multiple scans at once using the Project Navigator.
- Added support for deleting multiple annotations at once using the Project Navigator.
- Added a new option for removing regions automatically after converting regions to classifications.
- Added support to auto-rename the exported file if the file already exists after exporting regions.
- Improved Project Navigator annotations section to differentiate annotations and view states created using ReCap Pro and ReCap Viewer.
Mesh Editor:
- Added support for Layer Templates in the Mesh Editor.
- Added support for Custom Properties in the Mesh Editor.
- Added support for Select All in the Mesh Editor.
Recap Mesh for Revit:
- Updated UI to reflect Revit Modernisation.
- Removal of “Generic Object” from Add to Document/Family name.
Please post any feedback under User Forums > Reality Solutions > ReCap Pro.
Thanking You.
Warmest Regards,
Rishov Barman
Reality Capture
