[Bug] Recap 2026 25.1.2.377 - RCS export fails when exporting large RCP project without optimizing project or saving in same folder as previous export
- Version: Recap 2026 25.1.2.377
- Source file: e57 (embedded panoramas, 15.3 gb) from Navvis Ivion
Steps to replicate:
- I imported an e57P (what Ivion calls embedded panorama e57 files) into Recap
- Delete several points from point cloud
- Save file without optimizing
- Export as RCS (5mm) into same folder as a separate previous export doing the same steps above
- I also deleted the temp folder that is created by Recap prior to doing this and even restarted my PC afterwards
- Export window will stay stuck on 0% for 10+ minutes
Steps to resolve:
- Save as optimized point cloud (3D point cloud only, keep RealView as-is)
- Export as RCS into different folder than previous export
- Export will begin as normal and will successfully export
I'm not sure if it's trying to export without optimizing or saving into the same folder and deleting the temp folder that has caused the bug.
