![ReCap 360 Release Notes ReCap 360 Release Notes](https://forums.autodesk.com/t5/image/serverpage/image-id/244483iF4FFAD1C9813D880/image-size/original?v=v2&px=-1)
Please find below the release notes for Autodesk® ReCap 360 / Autodesk ReCap 360 Pro Update version 3.0.2.12
This release note contains the latest information regarding the installation and use of this update. It is strongly recommended that you read this entire document before you apply this update to your product. For reference, you should save this document to your hard drive or print a copy.
Affected Products
This update applies to the following products:
- Autodesk ReCap 360 / Autodesk ReCap 360 Pro (version: 3.0.1.5)
What is included?
This update contains the following fixes:
- Fix intermittent crash when closing app while a mesh is in progress.
- Fix issue where orbit can trigger zoom extents with orthographic cameras.
- Add documentation for new DeCap settings.
- Update Leica SDK for compatibility with new P16 firmware.
- Fix crash entering 3D registration preview.
- Update to latest Topcon SDK, including colorization support.
- Fix crash during import of some ZFS scans.
- Fix crash during import or auto-registration stemming from corrupt RCC file.
- Update structured E57 export to workaround compatibility issues w/ FARO Scene's E57 reader.
- Fix crash during import of some E57 files.
- Fix issue where P16 data may not show color properly in Revit.
- Add features to show, hide, isolate, and export the unassigned/default region.
- Fix issue where mirror balls would render incorrectly in orthographic 3D views.
- Fix issue with incorrect RealView generation from some Topcon data.
- Fix issue with creation of RealViews from some CL3 inputs.
- Fixed issue where annotations would not appear correctly in certain RealViews.
- Fixed incorrect mouse hover behavior on markups in certain RealView.
Installation Instructions
You must have administrative privileges on your Microsoft® Windows® operating system to complete the installation process.
Updating Autodesk ReCap 360 / Autodesk ReCap 360 Pro on a single computer:
1. Using Autodesk Desktop App:
- Ensure ReCap 360 / Autodesk ReCap 360 Pro version 3.0.1.5 is installed on the computer.
- Launch Autodesk Desktop App from the system tray or from Start -> Autodesk -> Autodesk Desktop App.
- Click on the 'Updates' tab; Autodesk ReCap 360 / Autodesk ReCap 360 Pro v3.0.2.12 should be visible in the list.
- Click on 'Install'. The new update will be downloaded and installed. ReCap 360 / Pro's current version 3.0.1.5 will be updated to version 3.0.2.12.
* More information on Autodesk Desktop App is available at: https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/About-Autodesk-desktop-a...
2. Direct download & install:
- Double click on AutodeskReCap360_3.0.1.5_to_3.0.2.12_x64.msp
- Follow the installation instructions on the screen. ReCap 360 / Pro's current version 3.0.1.5 will be updated to version 3.0.2.12.
Copyright © 2016 Autodesk, Inc.
