Fix NVIDIA Sound issues in Windows over OTG
TravisNave
Mentor Mentor
TravisNave
If your sound cuts out competely while using OTG in Windows, then you need to follow some steps to adjust some registry settings to resolve this.  I have verified this to work and have had success with other users performing these same steps.  The file is zipped below and is a Microsoft MHT web help file.  You can open it in Microsoft Edge, Microsoft Word, or an MHT viewer app on your phone.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
TravisNave
Edit:  I had to fix the contents of the attachment.  This one should open in Word.
Autodesk Forums:
