Powershape 2017 SP6 wrong dimensions
Hello, recently I have a problem when importing dwg files to Powershape.
All dimensions are wrong. For example line that is long 909mm in AutoCAD here is 23808.6mm.
Everything is ok with file, and I did not have that problem before. How to fix this?
909 x 25.4 = ....you have imperial/metric mix up.  John
Thanks, that is correct, but how can I fix that drawing. Units in my Powershape are metric, and should be ok. Scale down everything by 25.4?
jon.hunwick
Yes, scaling by 1/25.4 will correct the problem.
Jon Hunwick
 I had the same problem as you, but imported files was from completly diffrent CAD software.
I had many files to convert, so to solve this problem I wrote a macro:
SelectAll toolbar tools analysis toolbar tools edit EDIT SCALE VALUE 1/25,4 APPLY DISMISS EVERYTHING PARTIALBOX select clearlist VIEW EDIT TOP
And put it as a button in custom toolbar:
My macro a little bit more complicated, with set the lines, circles and dimensions to seperate levels, set the colour and style, set the view on top and set size of dimensions. If you also need something like this, just say it.
Mateusz
Problem is solved. Original files I have receieved were in .dwg format exported from Solidworks. In that conversion something happened and mixed up dimensions. I have tried to export the same files to .dxf and then when imported to Powershape everything is ok. Thanks everyone
