How to see miniatures of PSModels in Windows Explorer
Message 1 of 10
I want to see miniatures of my PSModels in windows explorer... This happened to me once a long time ago but I don't remember what I did exactly to handle it... Any suggestion?
Replies (9)
Message 2 of 10
suryakant.nirala
Hi @Anonymous
Thank you for placing your query on Autodesk Community!
As I can understand that You want to see PowerShape Models miniatures in the windows explorer.
You can refer the snapshot below:-
Please accept the solution button if my post fully solves your issue or reply with additional details if the problem persists.
Suryakant Nirala
Message 3 of 10
jonathan.artiss
Hi @Anonymous
Thank you for posting on the Autodesk Community forum!
Have a look at this thread here, I believe that this is the same issue you are having. If the solution in the mentioned thread works, please mark this answer as the solution.
Cheers,
Jonathan Artiss
Application Engineer
Submitting & Viewing Support Requests | Web Support | Phone Support
Message 4 of 10
It's still not working... I choose Large Or Extra Large Icons and choose Images for the folder... I really don't remember how I did last time this happened.
Message 5 of 10
Hey @jonathan.artiss,
They formatted the computer (Windows 7 64bits) and I put a fresh installation of PowerShape_2019.1.0... All the PSModels were saved with the option "Automatic Thumbnail" checked... And even when I save a new file it doesnt show the thumbnail in windows explorer.
Message 6 of 10
Chetan.Bankar
Hi @Anonymous,
Can you try to check the following,
  • Whether you are using Extra Large or Large icons for display of entities in the folder.
  • Whether option 'Always show icons, never thumbnails' is unchecked under Folder Options > View Tab.
If not then try settings this option and then follow the steps,
1) Save a new PowerShape model with option Thumbnail Save Mode is set to Automatic.
2) Close PowerShape.
3) Right-click on the newly saved PS model (*.psmodel) in the folder and select the context menu Properties.
I have notice that after closing PowerShape only the Thumbnail is displayed for the newly created and save PS model.
Thanks and Regards,
Chetan Bankar
Global Product Support
Message 7 of 10
Hey @Chetan.Bankar,
  • Whether you are using Extra Large or Large icons for display of entities in the folder. OK
  • Whether option 'Always show icons, never thumbnails' is unchecked under Folder Options > View Tab: Is Unchecked
  • Automatic Thumbnail Save in PowerShape Options Is Checked
  • PowerShape Closed and Reopened, Restarted the Windows: OK
Besides this, Any suggestions?
Best regards.
Message 8 of 10
Chetan.Bankar
@Anonymous wrote:
Hey @Chetan.Bankar,
Best regards.
Hi @Anonymous,
From the image supplied by you in post 4 of this thread it looks that the PowerShape PSmodel you saved in the folder is not being associated with PowerShape application. Please follow the steps below to resolve this
(they are for Windows 10 but should be similar for Windows 7):
1) Right-click on a .psmodel file
2) Select the "Open with..." option
3) Make sure the "Always use this app to open .psmodel files" option is checked
4) Choose PowerShape (you may have to navigate to the powershape.exe if it doesn't appear in the initial list of programs)
Once your files get associated with PowerShape then you can once again follow the steps mentioned here.
I hope this helps.
Thanks and Regards,
Chetan Bankar
Message 9 of 10
Sudhira
Autodesk Support
Autodesk Support
Hi Marcelolink,
Thanks for posting in Autodesk Community!!!
Please refer this snapshot by which I have highlight the option to check. After doing the changes, please click on the refresh button to get the desired result. Hope this will help to solve your issue.
If my post answers your query, please click on 'Accept as Solution' button.
Sudhira Dora
Message 10 of 10
Thank you guys, but it is still not working... This happened once time before but I don't remember what I did to handle it...
