after reinstalling powershape in my window 10 i have see a problem
is the problem project icon not show in small drawing image
i need some help to revover this problem
for more details please see attached file
Solved by amberg47. Go to Solution.
Solved by jonathan.artiss. Go to Solution.
Hi @amberg47
Thank you for posting on the Autodesk PowerShape forum!
Sometimes this needs to reset to look for the saved image, simply rebooting PowerShape will prompt this to connect the images to the file. You just need to ensure that the settings in your application options for Thumbnail Save Mode is set to Automatic.
Did closing and re-opening PowerShape force the images to update?
Cheers,
