PowerShape Forum
Welcome to Autodesk’s PowerShape Forums. Share your knowledge, ask questions, and explore popular PowerShape topics.
Creating a wireframe around a surface of a solid
8 REPLIES 8
Message 1 of 9
glen_h
819 Views, 8 Replies
First, is there a way to create a curve around a surface of a solid other than having to trace using composite curve?
I also do not want to convert the solid to surfaces.
Basically I'd like to select a surface of a solid and get a wireframe around that surface.
Second, I'd like to incorporate this into a macro if possible:
Macro would ask me to select a surface and then create a wireframe of the outline of that surface.
Glen
Big thanks to all who contribute!
My opinions are my own and are not intended to reflect yours.
8 REPLIES 8
Message 2 of 9
glen_h
in reply to: glen_h
If there are any Autodesk employees or developers monitoring this Forum, could you please chime in?
We are really trying to automate certain processes that are being done hundreds of times each month.
Glen
Message 3 of 9
CAMXPRESS
in reply to: glen_h
Hello Glenh,
Try to use the attached macro with the following steps:
1. Only one Solid visible. (Hide all the others)
2. Select the solid target solidsurface. (Let pink color the target solid surface)
3. Run the macro.
It should made what you like.
Joe
Tags (2)
Message 4 of 9
glen_h
in reply to: CAMXPRESS
Joe,
I think maybe the macro didn't upload in your post.
Glen
Message 5 of 9
CAMXPRESS
in reply to: glen_h
Hmm... Lets try it again ...
I cannot attach ..  Please copy this lines to any texteditor and save it ot .mac
TREEEDIT MODIFY COPY_FACE
DISPLAY BLANKSELECTED
SELECTALL
CREATE CURVE OUTLINE
PROJECT OFF
CONNECT ON
ACCEPT
QUICK QUICKSELECTSURFONLY
Delete
DISPLAY UNBLANK
Message 6 of 9
glen_h
Thank you Joe, That was exactly what I needed.
Glen
Message 7 of 9
CAMXPRESS
in reply to: glen_h
You are welcome Glenh!
If you like to set a shortcut key for that macro do the following:
1. Create an Addin with the following parameters: (change the location to yours)
2. Go to the File / Options / Customize Keyboard Shortcuts and do the following: (Change the key what you like)
Now you able to use keyboard shortcuts to this macro.
Hope it helps.
Joe
Message 8 of 9
glen_h
That's cool. Thanks again!
Message 9 of 9
glen_h
Hi Joe,
One quick question if you don't mind.
Let's say my solid is on level 301
Is there a way to detect that level #, save it as a variable, then place the composite curve onto Level 701 and activate that same level?
Basically, if my solid is on level 301 I would like to place the curve on level 701
If my solid is on level 302, then I'd like to place the curve on level 702, and so on.
Is this possible in Powershape?
I know I can assign variables in Powermill, then use if/then commands etc. Can this be done in Powershape?
Glen
