PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
macro to generate
9 REPLIES 9
Message 1 of 10
Ibisu_nert
859 Views, 9 Replies
macro to generate
hello, in my company we work with different parts such as caps, cavities and electrodes. We generate them in two post-processors, such as litz and fanuc.
example of generated folders
FANUC
h:\Cavities\cavity_37
LITZ
l:\Cavities\cavity\37
My question is: is there a macro that generates in both places with a different processed post specific for each path, fanuc H: and Litz L:, respecting the Path I put:
for example I put L:\cavities\cavity_37\Tombamentos
the same macro generates and then changes the pos to Fanuc and generates in
H:\cavidades\cavidade_37\Tombamento
9 REPLIES 9
Message 2 of 10
TK.421
in reply to: Ibisu_nert
here's a macro i wrote some time ago that does the same thing. you'll need to change the folder structure and post names of course.
Former Expert Elite Member (not enough participation in all their webinars and other "stuff", even though I beta test and regularly contribute to the betterment of the software and the PowerMill community as a whole)
the numbers never lie
Message 3 of 10
Ibisu_nert
in reply to: TK.421
I changed the processor folders but it didn't work for me
Message 4 of 10
TK.421
can you be a little more specific with the errors?
Message 5 of 10
Hi @Ibisu_nert   try this macro. Need to change paths !
// generate for 2 machines
EDIT NCPROGRAM ALL MESSAGES OFF
EDIT NCPROGRAM ALL COMMANDS BEFORE
EDIT NCPROGRAM ALL COMMANDS "/ {setupsheets.model.file_name}"
TPCOMMANDS ACCEPT
FOREACH ncprogram IN folder('NCProgram') {
ACTIVATE NCPROGRAM $ncprogram.Name
//machine 1
EDIT NCPROGRAM $ncprogram.Name FILENAME "D:\BLOCK\{ncprogram}s.mpf" //your destination folder
EDIT NCPROGRAM $ncprogram.Name TAPEOPTIONS FILEOPEN
"C:\FREZITE\Madeira\Centro de Maquinagem\PowerMILL\ductpost\2024\frezite_CBF-A-SIEMENS-TACV-AB_A8 2024.02.08.pmoptz" //your post 1
NCTOOLPATH APPLY
ACTIVATE NCPROGRAM $ncprogram.Name KEEP NCPROGRAM ; YES
//machine 2
EDIT NCPROGRAM $ncprogram.Name FILENAME "D:\BLOCK\{ncprogram}.tap"
"C:\FREZITE\Madeira\Centro de Maquinagem\PowerMILL\ductpost\2024\Ferrari AUT12-Elexa-9 2024.01.19.pmoptz" //your post 2
NCTOOLPATH APPLY
TEXTINFO ACCEPT
message info "Pronto!"
// TERMINADO
Message 6 of 10
YOU PT_BR?
Message 7 of 10
PT
Message 8 of 10
Ibisu_nert
does not execute. When debugging nothing happens, my powermil is 2020
maybe for this
Message 9 of 10
TK.421
did you change the extension from .txt to .mac? the debugger should show you errors
Message 10 of 10
Did you change the paths and post files?
