Macro to Export Selected Tools as Template Objects
evo80
Message 1 of 13
evo80
Good Day,
I'm trying to create this macro to export selected tools as *.ptf files to a location and drop them into folders based on their tool type, but It's not working for me, any ideas where I'm going wrong.
Thanks Jon K
DIALOGS MESSAGE OFF
DIALOGS ERROR OFF
GRAPHICS LOCK
IF $length(project_pathname(0)) == 0 {
	MESSAGE WARN 'Save project first.'
	MACRO ABORT ALL
IF $SIZE(folder('tool')) == 0 {
	MESSAGE WARN 'No tools in project.'
	MACRO ABORT ALL
PROJECT SAVE
STRING $pmlprj_content = ""
FOREACH $tl IN explorer_selected_entities() {
	IF $tl.type == 'tip_radiused'  {
STRING $template_path = "C:\Powermill\Template Objects\Tools\Tip Radiused"
}ELSE IF $tl.type == 'routing' {
STRING $template_path = "C:\Powermill\Template Objects\Tools\Routing"
    STRING $tool_name = "x" + $tl.ID + ".pmlent"
	STRING $tool_name_new = $tl.Name + ".ptf"
	STRING $tool_full = project_pathname(0) + "\" + $tool_name
	STRING $dest_path_full = $template_path + "\" + $tool_name_new
	COPY FILE $tool_full $dest_path_full
DIALOGS MESSAGE ON
DIALOGS ERROR ON
GRAPHICS UNLOCK
Replies (12)
Message 2 of 13
iamcdn79
Does this work?
DIALOGS MESSAGE OFF
DIALOGS ERROR OFF
GRAPHICS LOCK
    MACRO ABORT ALL
    MACRO ABORT ALL
PROJECT SAVE
        STRING $template_path = "C:\\Powermill\\Template Objects\\Tools\\Tip Radiused"
    } ELSE IF $tl.type == 'routing' {
        STRING $template_path = "C:\\Powermill\\Template Objects\\Tools\\Routing"
    STRING $tool_full = project_pathname(0) + "\\" + $tool_name
    STRING $dest_path_full = $template_path + "\\" + $tool_name_new
DIALOGS MESSAGE ON
DIALOGS ERROR ON
GRAPHICS UNLOCK
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 3 of 13
evo80
@iamcdn79 ,
Didn't work.
Here's the macro error I'm getting...
Macro Error:
File: C:\dcam\config\pmill2/Export-Selected-Tools.mac
Line: 20
Unexpected tokens found
Message 4 of 13
iamcdn79
Change to
 } ELSEIF $tl.type == 'routing' {
Windows 11 Pro
Message 5 of 13
evo80
Hmmm,
Same Error
Message 6 of 13
icse
I can't test it atm but somethimes checking enums in powermill in a loop/if statement does not work correctly try to create a string variable first and check those.
try this:
DIALOGS MESSAGE OFF
DIALOGS ERROR OFF
GRAPHICS LOCK
    MACRO ABORT ALL
    MACRO ABORT ALL
PROJECT SAVE
FOREACH $tl IN filter(explorer_selected_entities(),'this.RootType == "tool"') {
	string $e = $tl.type
    IF $e == 'tip_radiused' {
    } ELSE IF $e == 'routing' {
DIALOGS MESSAGE ON
DIALOGS ERROR ON
GRAPHICS UNLOCK
 also added a filter to the explorer selected enties so it does only work with tools
Message 7 of 13
evo80
Thanks for your help guys!
@icse , still getting that same macro error at
Macro Error:
Line: 22
Message 8 of 13
iamcdn79
Close, reopen the project and rerun the macro
Windows 11 Pro
Message 9 of 13
evo80
@iamcdn79 Same error.
Message 10 of 13
icse
I think you need to write the else if together.
Elseif
Message 11 of 13
evo80
Ok, I fiddled around with the code a bit, so when I select routing tools and run the macro it puts them into the correct folder, however when I select tip radiused tools it fails to populate the correct folder.
DIALOGS MESSAGE OFF
DIALOGS ERROR OFF
GRAPHICS LOCK
    MACRO ABORT ALL
    MACRO ABORT ALL
PROJECT SAVE
    } ELSEIF $e == 'routing' {
DIALOGS MESSAGE ON
DIALOGS ERROR ON
GRAPHICS UNLOCK
Message 12 of 13
icse
I looked it up in the debugger found some bugs, the $template_path variable is declared in the if statement and gets lost if the if block is closed also some {} where wrong.
I updated the macro so it works with every tool type out of the box:
if length(project_pathname(0)) == 0 OR project_modified() == 1 {
	bool $save = 0
	$save = query 'Save?'
	if $save {
		project save
	} else {
		return
foreach $t in filter(explorer_selected_entities(),'this.RootType == "tool"') {
	string $template_path = 'C:/Powermill/Template Objects/Tools/' + $t.type
	STRING $tool_name = "x" + $t.ID + ".pmlent"
	STRING $tool_name_new = $t.Name + ".ptf"
	STRING $tool_full = project_pathname(0) + "/" + $tool_name
	STRING $dest_path_full = $template_path + "/" + $tool_name_new
	if not dir_exists($template_path) {
		mkdir ${template_path}
	COPY FILE ${tool_full} ${dest_path_full}
You may have to change the / to \ in the path variable.
Message 13 of 13
evo80
Thanks so much, I've been wanting to migrate away from using the tool database and this has tidied up that decision.
Best Regards Jon K
