PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
macro to generate
6 REPLIES 6
Ibisu_nert
227 Views, 6 Replies
macro to generate
hello, in my company we work with different parts such as caps, cavities and electrodes. We generate them in two post-processors, such as litz and fanuc.
example of generated folders
FANUC
h:\Cavities\cavity_37
LITZ
l:\Cavities\cavity\37
My question is: is there a macro that generates in both places with a different processed post specific for each path, fanuc H: and Litz L:, respecting the Path I put:
for example I put L:\cavities\cavity_37\Tombamentos
the same macro generates and then changes the pos to Fanuc and generates in
H:\cavidades\cavidade_37\Tombamento
6 REPLIES 6
TK.421
in reply to: Ibisu_nert
here's a macro i wrote some time ago that does the same thing. you'll need to change the folder structure and post names of course.
the numbers never lie
Ibisu_nert
in reply to: TK.421
I changed the processor folders but it didn't work for me
TK.421
can you be a little more specific with the errors?
Hi @Ibisu_nert   try this macro. Need to change paths !
// generate for 2 machines
EDIT NCPROGRAM ALL MESSAGES OFF
EDIT NCPROGRAM ALL COMMANDS BEFORE
EDIT NCPROGRAM ALL COMMANDS "/ {setupsheets.model.file_name}"
TPCOMMANDS ACCEPT
FOREACH ncprogram IN folder('NCProgram') {
ACTIVATE NCPROGRAM $ncprogram.Name
//machine 1
EDIT NCPROGRAM $ncprogram.Name FILENAME "D:\BLOCK\{ncprogram}s.mpf" //your destination folder
EDIT NCPROGRAM $ncprogram.Name TAPEOPTIONS FILEOPEN
"C:\FREZITE\Madeira\Centro de Maquinagem\PowerMILL\ductpost\2024\frezite_CBF-A-SIEMENS-TACV-AB_A8 2024.02.08.pmoptz" //your post 1
NCTOOLPATH APPLY
ACTIVATE NCPROGRAM $ncprogram.Name KEEP NCPROGRAM ; YES
//machine 2
EDIT NCPROGRAM $ncprogram.Name FILENAME "D:\BLOCK\{ncprogram}.tap"
"C:\FREZITE\Madeira\Centro de Maquinagem\PowerMILL\ductpost\2024\Ferrari AUT12-Elexa-9 2024.01.19.pmoptz" //your post 2
NCTOOLPATH APPLY
TEXTINFO ACCEPT
message info "Pronto!"
// TERMINADO
YOU PT_BR?
PT
Technology Administrators
