Hi, is possible to put information inside macro pause?
I have more then 500 toolpath, I usually don't see all again, but lately I'm under pressure to get to effectively and less mistakes. So I need check alltoolpath,
I use a macro to select alltoolpath, and everytime I make resume, activates the next toolpath, etc etc
The ideia is me to see if something is missing.
Can I show data info inside macro pause Window?
Tool, feed ,speed , thickness, stepover?
Like create string, and macro pause $tool +ctrl $thickness
Solved by icse. Go to Solution.
something like that?
foreach $tp in folder('toolpath') {
activate toolpath ${tp.Name}
string $msg = $tp.Name + CRLF + $tp.Tool.Name + CRLF + $tp.Thickness + CRLF + $tp.Stepover + CRLF + $tp.FeedRate.Cutting.Value + CRLF + $tp.FeedRate.CuttingSpeed.Value
macro pause $msg
