PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
[macro] pattern check
4 REPLIES 4
moraschini
402 Views, 4 Replies
hello everyone, is possible check if 2 pattern are equal or not?
i have this 2 line on different level trnsfered from cad and i need to check if these are the same or not.
thanks in advance for the help
4 REPLIES 4
icse
in reply to: moraschini
you can try somehting like this:
entity $lvl1 = input entity level 'Select first'
entity $lvl2 = input entity level 'Select second'
EDIT MODEL ALL DESELECT ALL
EDIT LEVEL ${lvl1.Name} SELECT WIREFRAME
EDIT LEVEL ${lvl2.Name} SELECT WIREFRAME
string $p = new_entity_name('pattern')
CREATE PATTERN ;
EDIT PATTERN ${p} INSERT MODEL
EDIT PATTERN ${p} DESELECT ALL
EDIT PATTERN ${p} SELECT DUPLICATES
if number_selected('pattern', $p) != 0 {
	message info 'Equal'
} else {
	message info 'Not Equal'
purge pattern ${p} yes
I did not tested this properly, there might be some edge cases...
moraschini
in reply to: icse
hello @icse , is there a way to select only a colour of the level instead of all the level?
thanks in advance
icse
you can use this command to filter:
EDIT SELECTION MODEL FILTER '255, 128, 0'
//your color
EDIT SELECTION MODEL FILTER '255, 128, 26'
CREATE PATTERN ;
} else {
moraschini
in reply to: icse
Thank you very much @icse,
