PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Get all the user defined setting names and values?
4 REPLIES 4
hx
244 Views, 4 Replies
As the image show. How can I get all the user define names and values.
4 REPLIES 4
icse
in reply to: hx
hope this helps:
entity $tp = entity('toolpath','')
string $op = ''
foreach $key in $tp.UserParameters._keys {
	$op = $op + $key + ': ' + $tp.UserParameters[$key] + CRLF
message info $op
this should give you the keys and values in separate lists:
string list $keys = entity('toolpath','').UserParameters._keys
string list $values = apply($keys, 'entity("toolpath";"").UserParameters[this]')
and this should give you a map with key/value pairs:
object $kv = entity('toolpath','').Userparameters
hx
in reply to: icse
I am sorry, the problem description was not cleared. The user-defined parameter here is the user-defined parameter for the specified project
icse
in reply to: hx
thats a bit tricky
this gives you the parameter keys but i think there are some 'hidden' key value pairs not shown in the list:
project._keys
i take a closer look on this later
icse
in reply to: hx
try this:
//removes the project parameters set by powermill
string list $userPars = subtract(project._keys, {"Programmer","Customer","TextBlocks","HoleTagCatalog","FusionProductionJob","A360","ThicknessSets","PartName","ProjectHistory","Tolerances","OrderNumber","Notes"})
string $op = ''
foreach $k in $userPars {
		$op = $op + $k + ': ' + project[$k] + CRLF
message info $op
Technology Administrators
