Getting model size for post processor
erik.valtanen
erik.valtanen
I would like to know if you can somehow get the 3D-models dimensions used in a program to post prosessor. The "Block" parameter only seems to give you the extents of current toolpath and is not really giving accurate results in simulation and other things.
Block size.JPGI tried searching through program classes, but there is nothing resembling "Model". Can it be done?
Erik
rafael.sansao
You will need to use a macro to calculate the model limits and write the NC Program:
Real List Xmax = {}
Real List Xmin = {}
Real List Ymax = {}
Real List Ymin = {}
Real List Zmax = {}
Real List Zmin = {}
FOREACH $M IN FOLDER ("MODEL") {
	REAL ARRAY Lims[] = limits('model',$M.name)
	int a = add_last(Xmax, round($Lims[1],5))
	int b = add_last(Xmin, round($Lims[0],5))
	int c = add_last(Ymax, round($Lims[3],5))
	int d = add_last(Ymin, round($Lims[2],5))
	int e = add_last(Zmax, round($Lims[5],5))
	int f = add_last(Zmin, round($Lims[4],5))
Real Model_Max_X = max(Xmax)
Real Model_Min_X = min(Xmin)
Real Model_Max_Y = max(Ymax)
Real Model_Min_Y = min(Ymin)
Real Model_Max_Z = max(Zmax)
Real Model_Min_Z = min(Zmin)
KEEP NCPROGRAM ;
You will need to create 6 user parameters in your Postprocessor:
udp_Model_Max_X
udp_Model_Min_X
udp_Model_Max_Y
udp_Model_Min_Y
udp_Model_Max_Z
udp_Model_Min_Z
And add to the commands:
This link can help you: https://forums.autodesk.com/t5/powermill-forum/replace-a-character-in-file-with-a-macro/m-p/6774411#...
Rafael Sansão
OptiNC - www.optinc.tech
