2019 licensing issue
kukelyk
Advisor Advisor
kukelyk
after generating new autodesk license, Pm2018 runs correctly, but 2019 does not.
What can be the problem?
jonathan.artiss
Hi @kukelyk
Thank you for posting on the Autodesk PowerMill forum!
I would suggest seeking assistance through the installation and licensing forum, they would  be better suited to assist you with this issue.
If you have a screenshot of an error or any other information, attach it to the new thread on that forum.
You could also contact your local support by phone or support request though your Autodesk Account as shown here
Cheers,
Jonathan Artiss
Application Engineer
Submitting & Viewing Support Requests | Web Support | Phone Support
If you're using network licensing, you probably need to update the Autodesk Network License Manager on your license server.  I had the same issue, and it worked for me.
Jacob
rafael.sansao
kamalrajcv
Hi @kukelyk
I am looking at the unresolved forum posts.
Has any of the replies helped you to solve the problem you were facing?
Do you need further help with this?
Can you please select the reply that solved your issue by clicking the "Accept Solution" button available under each reply?
Accepting a solution will mark your topic as solved, and highlight the reply in the topic so others having the same issue can more easily view the solution.
Kamalraj C V
Technical Support Specialist
kukelyk
Hi @kamalrajcv
I think it is working, but still not tested..
