- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
after generating new autodesk license, Pm2018 runs correctly, but 2019 does not.
What can be the problem?
Hi @kukelyk
Thank you for posting on the Autodesk PowerMill forum!
I would suggest seeking assistance through the installation and licensing forum, they would be better suited to assist you with this issue.
If you have a screenshot of an error or any other information, attach it to the new thread on that forum.
You could also contact your local support by phone or support request though your Autodesk Account as shown here.
Cheers,
If you're using network licensing, you probably need to update the Autodesk Network License Manager on your license server. I had the same issue, and it worked for me.
Jacob
For Autodesk 2019 products, updating is required.
Hi @kukelyk
I am looking at the unresolved forum posts.
Has any of the replies helped you to solve the problem you were facing?
Do you need further help with this?
Can you please select the reply that solved your issue by clicking the "Accept Solution" button available under each reply?
Accepting a solution will mark your topic as solved, and highlight the reply in the topic so others having the same issue can more easily view the solution.
Hi @kamalrajcv
I think it is working, but still not tested..
