Добрый день!
Скачал установщик Inventor 2020 под Windows 10 64 бит. Однако при установке постоянно выдает ошибку, будто я запускаю 32 разрадную версию установщика. Скрины ошибки и какой именно файл запускаю в приложении. ОС Windows 10 Corporate Edition 64 bit.
Решено! Перейти к решению.
Решено: Alexander.Rivilis. Перейти к решению.
@Anonymous
This is an English speaking forum and when your posting is translated we see this
Good day!
Downloaded the installer Inventor 2020 under Windows 10 64 bits. However, when installing, I constantly get an error, as if I was running the 32-bit version of the installer. Error screens and which file I launch in the application. Windows 10 Corporate Edition 64 bit.
Most likely you are missing crucial Win 10 updates. I would start there. In addition you're using the web installer method. Don't use that method. There's a couple of ways to properly download and install your Autodesk product to your machine. Please review this article and the solution it provides.
Also for the future and best results.. Post in the installation and licensing forum when you have issues related to installation of your Autodesk product. https://forums.autodesk.com/t5/installation-licensing/bd-p/24
Or you can post in your native language using the related forum: https://forums.autodesk.com/t5/russkiy/ct-p/5056
Mark Lancaster
& Autodesk Services MarketPlace Provider
Can you help this user?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
@cbenner Thanks for pointing me here.
So I am moving this thread to russian forums to take care of you @Anonymous
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Добрый день!
Подскажите, пожалуйста, откуда вы скачали дистрибутив?
Можете также приложить логи установки?
Я вижу, что в названии дистрибутива указано 64, но ваша система ругается...у вас есть права администратора в системе?
@Anonymous
Выполните эти рекомендации: Рекомендуемые действия при установке ПО Autodesk
Попробуйте скачать эти три части в один каталог и запустите на выполнение первую часть:
Если будут ошибки при установке выкладывайте сюда все log-файлы.
Facebook | Twitter | LinkedIn
Не нашли то, что искали? Задайте вопросы в сообществе или поделитесь своими знаниями.
