Подписка, лицензирование и установка – только для чтения
В данном разделе вы найдете ответы по планам подписки Autodesk, решить вопросы по лицензированию и установке программного обеспечения.
установка демоверсии Inventor 2020 на Windows 10 Corporate Edition 64 bit
5 REPLIES 5
1039 Views, 5 Replies
Добрый день!
Скачал установщик Inventor 2020 под Windows 10 64 бит. Однако при установке постоянно выдает ошибку, будто я запускаю 32 разрадную версию установщика. Скрины ошибки и какой именно файл запускаю в приложении. ОС Windows 10 Corporate Edition 64 bit.Inventor_error1.jpgInventor_error2.jpg
5 REPLIES 5
Mark.Lancaster
@Anonymous
This is an English speaking forum and when your posting is translated we see this
Good day!
Downloaded the installer Inventor 2020 under Windows 10 64 bits. However, when installing, I constantly get an error, as if I was running the 32-bit version of the installer. Error screens and which file I launch in the application. Windows 10 Corporate Edition 64 bit.
Most likely you are missing crucial Win 10 updates.  I would start there.  In addition you're using the web installer method.  Don't use that method.   There's a couple of ways to properly download and install your Autodesk product to your machine.  Please review this article and the solution it provides.
Also for the future and best results..  Post in the installation and licensing forum when you have issues related to installation of your Autodesk product.  https://forums.autodesk.com/t5/installation-licensing/bd-p/24
Or you can post in your native language using the related forum: https://forums.autodesk.com/t5/russkiy/ct-p/5056
Mark Lancaster
lena.talkhina
in reply to: cbenner
@cbenner Thanks for pointing me here.
So I am moving this thread to russian forums to take care of you @Anonymous
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
lena.talkhina
Добрый день!
Подскажите, пожалуйста, откуда вы скачали дистрибутив?
Можете также приложить логи установки?
Я вижу, что в названии дистрибутива указано 64, но ваша система ругается...у вас есть права администратора в системе?
Alexander.Rivilis
@Anonymous
Выполните эти рекомендации: Рекомендуемые действия при установке ПО Autodesk
Попробуйте скачать эти три части в один каталог и запустите на выполнение первую часть:
https://efulfillment.autodesk.com/NetSWDLD/2020/INVPROSA/A54F6B0D-5695-4B11-A54F-C2D2C6E9D1EA/SFX/Inventor_Pro_2020_Russian_Win_64bit_dlm_001_003.sfx.exe?authparam=1559841596_2afa1781f1cca3be2739637a8817f0f6&SESSION_ID=1558041596473&ext=.exe
https://efulfillment.autodesk.com/NetSWDLD/2020/INVPROSA/A54F6B0D-5695-4B11-A54F-C2D2C6E9D1EA/SFX/Inventor_Pro_2020_Russian_Win_64bit_dlm_002_003.sfx.exe?authparam=1559841596_ea60cf9b596da10a8011a28f6df70102&SESSION_ID=1558041596473_2&ext=.exe
https://efulfillment.autodesk.com/NetSWDLD/2020/INVPROSA/A54F6B0D-5695-4B11-A54F-C2D2C6E9D1EA/SFX/Inventor_Pro_2020_Russian_Win_64bit_dlm_003_003.sfx.exe?authparam=1559841596_ac3497ee90d2ae20af108aaa8338ebd9&SESSION_ID=1558041596473_3&ext=.exe
Если будут ошибки при установке выкладывайте сюда все log-файлы.
Facebook | Twitter | LinkedIn
Expert Elite Member
