Does Autodesk have, making the move to .Net Core, on their "future update" roadmap?
I hope so, also we will need as much forewarning as possible.
Solved by kdub_nz. Go to Solution.
Long Story short
Yes.
https://forums.autodesk.com/t5/net/this-info-affects-us-all/m-p/12135783#M78047
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>; another Swamper
You may be interested in this
https://www.theswamp.org/index.php?topic=58388.msg615240#msg615240
