.NET
Lines are closed profile or not
2 REPLIES 2
samiranjith1
218 Views, 2 Replies
if i have list of lines, How to check those lines can make a closed profile or not  ?
Tags (2)
Labels (1)
2 REPLIES 2
jabowabo
in reply to: samiranjith1
Line.Closed = true/false
hippe013
To determine if a list of lines can create a closed figure is similar to a surveyor determining if a traverse closes. For each line determine the delta X and the delta Y. If the sum of the delta X and the sum of the delta Y both equal zero. Then the list of lines creates a closed figure. The square root of the (sum of the delta X) squared plus the (sum of the delta Y) squared is known as the "Error of Closure".
Technology Administrators
