Is it possible to move a DBDictionary?
This page suggests it is:
I can't seem to figure out what sort of syntax is needed to achieve it.
Solved by _gile. Go to Solution.
This method is 'protected'. This mean the method is only accessible within the DBDictionary class (same as 'private') and derived classes.
To "copy" a DBDictionary within the same Database, you should try the DeepCloneObjects() method.
To "copy" a DBDictionary from a Database to another one, you should try the WBlockCloneObjects() method.
