.NET
Model is out of layout
4 REPLIES 4
BestFriendCZ
479 Views, 4 Replies
Hi all,
i wuld like to know if there is easy way how to check this. I know how to find min,max coordinates in my ViewPort. If i transform model cordinates (UCS) to paperspace so these coordinates are still same... doesn't matter to scale setting. Model cordinates change only if i move with model.
Reason why i need this is:
our designers use scales like 1:100 if isn't enough then 1:150 and etc.. i can't use zoom extents or something similar
thank you for any advices
4 REPLIES 4
BestFriendCZ
in reply to: BestFriendCZ
Hi all,
i didn't find some ideal solution. My plan is prepare some logic like:
if model BB is lower then 25m then 1:100 scale
if model BB bethween 25-40m then 1:150 scale
40m and more 1:200 scale
all my structure have profil rectangular so i will compare their width
.... but is really the best solution? i don't think so
What about using Zoom Extents to calculate the nearest standard scale?
@BestFriendCZ wrote:
Hi all,
Hi ActivistInvestor
you have right. This is definitely better solution. Thank you for your advice
BestFriendCZ
//input si CustomScale after use ZoomExtents
public static double FindNearestScale(double input)
//1:100, 1:200, 1:150 in order
double[] possibleScales = new double[] { 0.01,0.05,0.006666,};
try
return possibleScales.Aggregate((current, next) => Math.Abs(current - input) < Math.Abs(next - input) ? current : next);
catch { return 0.01; }
Forma Design Contest
