.NET
Is the "Fill Entire Path" property of an Array Path object exposed?
1 REPLY 1
jdowthwaite
494 Views, 1 Reply
Is it possible to set the "Fill Entire Path" property of an Array Path object?
I can barely find any documentation on this object, and the AssocArrayPathParameters entity exposed in the API doesn't have a property that seems to match up.
I've got an Array Path generating due to this article but can't set this one variable to "True": http://www.keanw.com/2011/11/creating-a-simple-associative-autocad-array-along-a-path-using-net.html
1 REPLY 1
moogalm
in reply to: jdowthwaite
AcDbAssocArrayPathParameters :: [set]fillEntirePath
API is not public exposed
I will send you a wish request through SFDC you can provide a business case against wish request.
Forma Design Contest
AutoCAD Beta
