.NET
Integrate Dynamo with Autocad
51 REPLIES 51
Message 1 of 52
Yonas89
37952 Views, 51 Replies
I am not sure which forum to choose for my question, thus I hope I have chosen the right one. I have read and watched about Dynamo compatibility with Revit and it looks just amazing. However I use Civil 3d in my daily process which is AutoCAD based and though it's  challenging  to combine Dynamo with AutoCAD, I know it's possible, but I don't know how. I would like to discuss with you guys, maybe you have some experience with it or some thoughts to share. I have found this short video here: https://www.youtube.com/watch?v=oiz76GTN-8Y. Sorry that it's in Russian, don't understand Russian but I get the point that AutoCAD objects could be controlled from Dynamo.
51 REPLIES 51
Message 2 of 52
Alexander.Rivilis
in reply to: Yonas89
@Anonymous
It is a question for you.
@Yonas89
You can ask @Anonymous in PM about Dynamo & AutoCAD.
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 52
Hello. You're right, Dynamo can integrate with AutoCAD. Say what you want to solve the problem and I'll show you a solution.
Message 4 of 52
Yonas89
in reply to: Alexander.Rivilis
Hello, thanks a lot for tagging the author of the video. This is great.
Message 5 of 52
Yonas89
Hello @Anonymous,
I do not have any specific task yet actually, I am just trying to understand the limits of Dynamo  implementation in civil engineering.  I think that Civil 3D with Subassembly composer is okay for making dynamic road. However I am thinking to use Dynamo for making some infrastructure elements such as intersections, roundabouts, driveways or culverts to make it parametric as much as possible.
Message 6 of 52
Well, if you do not have a specific task, then I'll show you how to build the line in the open AutoCAD file.
restart = IN[0]
if IN[1] != True: off = 1/0
import clr
clr.AddReference('ProtoGeometry')
import Autodesk
from Autodesk.DesignScript.Geometry import *
import System
from System import *
app = System.Runtime.InteropServices.Marshal.GetActiveObject("Autocad.Application")
AcDoc = app.ActiveDocument
lines = IN[2]
def ptA(p):
	return Array[float]([p.X, p.Y, p.Z])
for k in lines:
	stpt = ptA(k.StartPoint)
	enpt = ptA(k.EndPoint)
	linn = AcDoc.ModelSpace.AddLine(stpt, enpt)
Message 7 of 52
Download Dynamo file https://yadi.sk/d/TEdi5lwcyHmn6
Message 8 of 52
This inverse problem. Get a dedicated line from AutoCAD
restart = IN[0]
import clr
import Autodesk
import System
DPoint = Autodesk.DesignScript.Geometry.Point
DLine = Autodesk.DesignScript.Geometry.Line
def ptD(p):
	return DPoint.ByCoordinates(p[0],p[1],p[2])
def linD(p1,p2):
	return DLine.ByStartPointEndPoint(ptD(p1),ptD(p2))
sset = AcDoc.PickfirstSelectionSet
n = sset.Count
curvs = []
for i in range(n):
	if sset.Item(i).EntityName == "AcDbLine":
		stpt = sset.Item(i).StartPoint
		enpt = sset.Item(i).EndPoint
		lns = linD(stpt,enpt)
		curvs.append(lns)
OUT = curvs
download Dynamo file https://yadi.sk/d/xDnbn2EHyHtdK
Message 9 of 52
Slawomir_
I can't find "ForceChildrensEval" on the web. Where can I find this or how can I make this in Dynamo?
Tags (2)
Message 10 of 52
in reply to: Slawomir_
This node from Prorubim DS Common Kit package
Message 11 of 52
Slawomir_
Thanks! Is it free for commercial use?
Message 12 of 52
its free
Message 13 of 52
Slawomir_
I'm stuck. Did complete sample You have shown but now I don't know how to display this Python text window.
Dynamo 0.9.1
Message 14 of 52
Double click to Python Script node
Message 15 of 52
Slawomir_
It's working! Thanks a lot!
Message 16 of 52
Smiley Wink
Message 17 of 52
is it possible to import information from Excel to property set data in Autocad Architecture?
Message 18 of 52
Yonas89
Hmm, I think with Dynamo it would be possible but difficult. I think the better option would be to create custum plugin for it.
Message 19 of 52
That's possible.
Message 20 of 52
Of course it would be good to write a plugin, but in what programming language? In Dynamo there are nodes to work with Excel, it is already good
Forma Design Contest
AutoCAD Beta
