.NET
How to get block boundary to trim lines inside it
2 REPLIES 2
ahmedshawkey95
1095 Views, 2 Replies
I can split lines/curves inside a specific bounding curve, but is there is a way to get a block bounding curve to allow me to trim lines inside it as shown below?
Labels (2)
2 REPLIES 2
If you have read the recent post in this forum a few days ago, you may have already had an idea how to solve this issue. But since I saw these 2 questions out of a very similar use context, I put together some code to demonstrate my proposed solution and published in my blog for better code presentation. See here:
https://drive-cad-with-code.blogspot.com/2020/11/find-lines-intersection-points-with.html
Norman Yuan
Drive CAD With Code
@norman.yuan awesome idea as usual. I'll continue working on it to achieve my requirements.
Thanks.
Forma Design Contest
