.NET
Get layers from current file only (not referenced files)
6 REPLIES 6
ottosson_mathias
1493 Views, 6 Replies
I'm trying to get all layers from a file. But I get all layers from the referenced files as well, and I don't know how to distinguish them from one and other.
using (Transaction transaction = db.TransactionManager.StartTransaction())
    var layerTable = transaction.GetObject(db.LayerTableId, OpenMode.ForRead) as LayerTable;
    foreach (var layer in layerTable)
        var currentLayer = layer.GetObject(OpenMode.ForRead) as LayerTableRecord;
        // Check if layer is from current file or referenced file...
    transaction.Commit();
How can I know if a layer belongs to an external reference and not the opened file?
6 REPLIES 6
_Tharwat
in reply to: ottosson_mathias
Layer names that belong to external files contain the pipe symbol ( | ) within every layer name so you need to check if the layer name has not that symbol.
ottosson_mathias
in reply to: _Tharwat
I was thinking about that as well, and now I double checked and it's not possible to name a layer using |.
So if there is no other way I guess that could work. Even though it feels a bit inefficient to have to check the names.
I also tried to detach all xrefs, which worked, and that felt a bit more efficient, but hacky...
_Tharwat
How come it is inefficient to check each name of the layer from the Layer Table ?
I used to have tens of operations in a program then the codes running as fast as a blink of an eye without any delay.
You can use IsDependent property.
Quote from arx documentation:
"Returns true when the SymbolTableRecord is a dependent (that is, part of) of an attached xref drawing; otherwise false is returned."
               if (currentLayer.IsDependent)
                   //is part of a xref drawing
               else
                   //not part of a xref drawing
hosneyalaa
in reply to: sudokuxls
namespace Layering
    public class LayersGroup
        short colorindex = 1;
        [CommandMethod("GL", CommandFlags.UsePickSet)]
        public void GroupLayers()
            Dictionary<string, List<Entity>> entitiesList = new Dictionary<string, List<Entity>>();
            Database db = Application.DocumentManager.MdiActiveDocument.Database;
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            StringBuilder sb = new StringBuilder("List of created layers:"+System.Environment.NewLine);
            using (Transaction trans = db.TransactionManager.StartTransaction())
                PromptSelectionResult sPrompt = ed.SelectImplied();
                if (sPrompt.Status != PromptStatus.OK)
                    sPrompt = ed.GetSelection();
                if (sPrompt.Status == PromptStatus.OK)
                    foreach (SelectedObject item in sPrompt.Value)
                        if (item != null)
                            Entity entity = trans.GetObject(item.ObjectId, OpenMode.ForWrite) as Entity;
                            if (entity != null)
                                string s = entity.GetType().Name;
                                switch (s)
                                    case "DBText":
                                    case "MText":
                                        s = "Text";
                                        break;
                                    default:
                                        break;
                                if (!entitiesList.ContainsKey(s))
                                    entitiesList.Add(s,new List<Entity>());
                                entitiesList[s].Add(entity);
                    LayerTable lT = trans.GetObject(db.LayerTableId, OpenMode.ForWrite) as LayerTable;
                    foreach (var item in entitiesList.Keys)
                        sb.AppendLine(item);
                        if (!lT.Has(item))
                            LayerTableRecord newLayer = new LayerTableRecord();
                            newLayer.Name = item;
                            newLayer.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByAci, colorindex++);
                            lT.Add(newLayer);
                            trans.AddNewlyCreatedDBObject(newLayer, true);
                        foreach (var ent in entitiesList[item])
                            ent.Layer = item;
That looks like the approach I was expecting! Thanks!
Forma Design Contest
