I'm trying to get all layers from a file. But I get all layers from the referenced files as well, and I don't know how to distinguish them from one and other.
using (Transaction transaction = db.TransactionManager.StartTransaction())
var layerTable = transaction.GetObject(db.LayerTableId, OpenMode.ForRead) as LayerTable;
foreach (var layer in layerTable)
var currentLayer = layer.GetObject(OpenMode.ForRead) as LayerTableRecord;
// Check if layer is from current file or referenced file...
transaction.Commit();
How can I know if a layer belongs to an external reference and not the opened file?
Solved by sudokuxls. Go to Solution.
Layer names that belong to external files contain the pipe symbol ( | ) within every layer name so you need to check if the layer name has not that symbol.
I was thinking about that as well, and now I double checked and it's not possible to name a layer using |.
So if there is no other way I guess that could work. Even though it feels a bit inefficient to have to check the names.
I also tried to detach all xrefs, which worked, and that felt a bit more efficient, but hacky...
@ottosson_mathias wrote:I guess that could work. Even though it feels a bit inefficient to have to check the names.
How come it is inefficient to check each name of the layer from the Layer Table ?
I used to have tens of operations in a program then the codes running as fast as a blink of an eye without any delay.
You can use IsDependent property.
Quote from arx documentation:
"Returns true when the SymbolTableRecord is a dependent (that is, part of) of an attached xref drawing; otherwise false is returned."
if (currentLayer.IsDependent)
//is part of a xref drawing
else
//not part of a xref drawing
namespace Layering
public class LayersGroup
short colorindex = 1;
[CommandMethod("GL", CommandFlags.UsePickSet)]
public void GroupLayers()
Dictionary<string, List<Entity>> entitiesList = new Dictionary<string, List<Entity>>();
Database db = Application.DocumentManager.MdiActiveDocument.Database;
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
StringBuilder sb = new StringBuilder("List of created layers:"+System.Environment.NewLine);
using (Transaction trans = db.TransactionManager.StartTransaction())
PromptSelectionResult sPrompt = ed.SelectImplied();
if (sPrompt.Status != PromptStatus.OK)
sPrompt = ed.GetSelection();
if (sPrompt.Status == PromptStatus.OK)
foreach (SelectedObject item in sPrompt.Value)
if (item != null)
Entity entity = trans.GetObject(item.ObjectId, OpenMode.ForWrite) as Entity;
if (entity != null)
string s = entity.GetType().Name;
switch (s)
case "DBText":
case "MText":
s = "Text";
break;
default:
break;
if (!entitiesList.ContainsKey(s))
entitiesList.Add(s,new List<Entity>());
entitiesList[s].Add(entity);
LayerTable lT = trans.GetObject(db.LayerTableId, OpenMode.ForWrite) as LayerTable;
foreach (var item in entitiesList.Keys)
sb.AppendLine(item);
if (!lT.Has(item))
LayerTableRecord newLayer = new LayerTableRecord();
newLayer.Name = item;
newLayer.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByAci, colorindex++);
lT.Add(newLayer);
trans.AddNewlyCreatedDBObject(newLayer, true);
foreach (var ent in entitiesList[item])
ent.Layer = item;
