Where Did Application.AcadApplication Go?
I'm trying to write a method to zoom to the extents of a drawing in AutoCAD using C#.NET and the latest version of ObjectARX. I googled for an example of someone doing that and found this post which has the following method:
[CommandMethod("zoomExtentTest")]
public static void zoomExtentTest()
    //using InvokeMember to support .NET 3.5
    Object acadObject = Application.AcadApplication;
    acadObject.GetType().InvokeMember("ZoomExtents"BindingFlags.InvokeMethod, null, acadObject, null);
When I tried to copy the code I got an error saying Autodesk.AutoCAD.ApplicationServices.Application has no defintion for AcadApplication so I'm guessing it got replaced with something else but I don't know where I'd find such a replacement or how I'd rewrite the above method to work with the current AutoCAD .NET API.
Ed__Jobe
With the corrent 'using' statement, it should work.
using acApp = Autodesk.AutoCAD. ApplicationServices.Application;
I use acApp because if you reference System, you will end up with amibiguous references to 'Application'. So you need to change the following line to:
Object acadObject = acApp.AcadApplication;
Note that you could search for 'AcadApplication' in the Object Browser (Ctrl + W) to find references.
Ed
How to post your code.
Figured out what happened, I was referencing
Autodesk.AutoCAD.ApplicationServices.Core.Application
instead of
Autodesk.AutoCAD.ApplicationServices.Application.
Thanks for your help!
