What is the API for "Limits" command in model space
哀家爆
哀家爆
I can manually input command "Limits" to set the extents of model space. And is there any api to access to write/get this property. So far all I've found is "Layout.Limits" and this property is read-only.
_gile
You can set the Database.Mimmin and Database.Limmax properties.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
哀家爆
Thanks. Your suggest works very well.
            var bb = CalculateBoundingBox(regionModel.BoundaryLines);
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            using (var ts = doc.TransactionManager.StartTransaction())
                db.Limmin = new Point2d(bb[0], bb[2]);
                db.Limmax = new Point2d(bb[1], bb[3]);
                ts.Commit();
_gile
You do not need to start a transaction to change these system variables.
Gilles Chanteau
GileCAD
GitHub
