Deserializing an object from another assmebly?
nshupeFMPE3
Message 1 of 1
nshupeFMPE3
I am in the process of re-writing our plugin, which means a whole new assembly. I am trying to maintain backwards compatability with our old plugin for when the time comes that we switch over.
The problem I'm running into is some data was written to an XRecord in the form of a List of objects from the old assembly. So the old assembly has an interface IZone, and the XRecord data is a List<IZone> that was serialized in this way
public static ResultBuffer SerializeXrecordData(object objectToSerialize)
            ResultBuffer buffer;
            MemoryStream serializationStream = new MemoryStream();
            try
                new BinaryFormatter().Serialize(serializationStream, objectToSerialize);
                byte[][] bufferArray = ChunkStream(serializationStream);
                if (bufferArray.Length <= 0)
                    buffer = null;
                else
                    List<TypedValue> list = new List<TypedValue> {
                        new TypedValue(1, objectToSerialize.GetType().FullName)
                    int index = 0;
                    while (true)
                        if (index >= bufferArray.Length)
                            buffer = new ResultBuffer(list.ToArray());
                            break;
                        list.Add(new TypedValue(310, bufferArray[index]));
                        index++;
            finally
                if (!ReferenceEquals(serializationStream, null))
                    serializationStream.Dispose();
            return buffer;
public static byte[][] ChunkStream(MemoryStream stream)
            byte[][] bufferArray = new byte[(int) Math.Ceiling((decimal) (stream.Length / 127M))][];
            stream.Position = 0L;
            int index = 0;
            int length = (int) stream.Length;
            int num4 = 0;
            while (true)
                if (length <= 0)
                    break;
                int count = 0x7f;
                if (count > length)
                    count = length;
                byte[] buffer = new byte[count];
                int num6 = stream.Read(buffer, 0, count);
                if (num6 == 0)
                    break;
                bufferArray[index] = buffer;
                index++;
                length -= num6;
                num4 += num6;
            return bufferArray;
I have made a copy of the C# file for the IZone Interface in my new project so that I would have the type.
And when I try to deserialize and casting to List<IZone> using the deserialization method from the old assembly I get an error saying
Object of Type [CompanyName]Tools.Interfaces.IZone[] cannot be cast to type [CompanyName]Tools.Interfaces.IZone[]
This is how the deserialization occurs
public static object DeSerializeXrecordData(ResultBuffer xrecordData)
            object obj2;
            bool flag = xrecordData != null;
            if (!flag)
                obj2 = null;
            else
                BinaryFormatter formatter = new BinaryFormatter {
                    Binder = new DomainBinder()
                try
                    TypedValue[] valueArray = xrecordData.AsArray();
                    int index = 1;
                    while (true)
                        flag = index < valueArray.Length;
                        if (!flag)
                            serializationStream.Position = 0L;
                            obj2 = formatter.Deserialize(serializationStream);
                            break;
                        if (valueArray[index].TypeCode == 310)
                            byte[] buffer = (byte[]) valueArray[index].Value;
                            serializationStream.Write(buffer, 0, buffer.Length);
                        index++;
                finally
            return obj2;
public class DomainBinder : SerializationBinder
            public override Type BindToType(string assemblyName, string typeName)
                string str = assemblyName.Split(new char[] { ',' })[0];
                Assembly[] assemblies = AppDomain.CurrentDomain.GetAssemblies();
                int index = 0;
                while (true)
                    Type type;
                    if (index >= assemblies.Length)
                        type = null;
                    else
                        char[] separator = new char[] { ',' };
                        if (str != assemblies[index].FullName.Split(separator)[0])
                            index++;
                            continue;
                        type = assemblies[index].GetType(typeName);
                    return type;
I know this is a weird/hard one, but any help would be greatly appreciated
Replies (0)
