Slow ResultBuffer
Slow ResultBuffer
office
Slow ResultBuffer
office
I want to save a lot of data in DWG via XRecord but when making the ResultBuffer for it, it is very slow.
Here is a sample code for the ResultBuffer:
        public static void SaveSurfaceDataToDictionary(string dictName)
            ResultBuffer resultBuffer = new ResultBuffer();
            foreach (long objectHandle in Lisp.plineHandleList) //List length = 59260
                resultBuffer.Add(new TypedValue((int)DxfCode.Handle, objectHandle));
            SetXrecord(dictName, "ObjectHandleList", resultBuffer);
            foreach (TriangleNet.Geometry.Vertex v in Lisp.polygonList.Points) //List length = 22766
                resultBuffer.Add(new TypedValue((int)DxfCode.UcsOrg, new Point3d(v.X, v.Y, v.Z)));
            SetXrecord(dictName, "PolygonPointsList", resultBuffer);
            List<ISegment> segmentList = Lisp.polygonList.Segments;
            foreach (Segment segment in segmentList) //List length = 17022
                TriangleNet.Geometry.Vertex v;
                v = segment.GetVertex(0);
                v = segment.GetVertex(1);
            SetXrecord(dictName, "PolygonSegmentsList", resultBuffer);
        public static void SetXrecord(string dictName, string key, ResultBuffer resbuf)
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                DBDictionary NOD =
                    (DBDictionary)tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead);
                DBDictionary dict;
                if (NOD.Contains(dictName))
                    dict = (DBDictionary)tr.GetObject(NOD.GetAt(dictName), OpenMode.ForWrite);
                else
                    dict = new DBDictionary();
                    NOD.UpgradeOpen();
                    NOD.SetAt(dictName, dict);
                    tr.AddNewlyCreatedDBObject(dict, true);
                Xrecord xRec = new Xrecord();
                xRec.Data = resbuf;
                dict.SetAt(key, xRec);
                tr.AddNewlyCreatedDBObject(xRec, true);
                tr.Commit();
The ResultBuffer operation takes 12 seconds. Way to slow.
Any idea or alternative for this?
I want to keep my data in DWG database.
_gile
Except the fact you could start the transaction and get or or create the dictionary only once in the SaveSurfaceDataToDictionary() method ans pass them to the SetXrecord() method I do not see anything unefficient in your code structure.
But we do not know anything about the custom objects you use (Lisp, TriangleNet.Geometry.Vertex, Segment). The implementation of these types may be the cause of the slow down.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
office
The custom objects are alright.
The problem is the resultbuffer.
Here is a sample code which takes 21 seconds without any implementations:
            for (int i = 0; i < 50000; i++)
                resultBuffer.Add(new TypedValue((int)DxfCode.Int32, i));
_gile
I made some tests and it looks like it is the Resultbuffer.Add() method which is very slow.
You should use the overload ResultBuffer(params TypedValue[])  constructor instead.
        [CommandMethod("BENCH")]
        public static void Bench()
            var ed = Application.DocumentManager.MdiActiveDocument.Editor;
            BenchArray(ed);
            BenchAdd(ed);
        public static void BenchArray(Editor ed)
            var sw = new Stopwatch();
            sw.Start();
            var tvs = new TypedValue[50000];
                tvs[i] = new TypedValue((int)DxfCode.Int32, i);
            ResultBuffer resbuf = new ResultBuffer(tvs);
            sw.Stop();
            ed.WriteMessage($"\nElapsed milliseconds to build from a TypedValues array: {sw.ElapsedMilliseconds}");
        public static void BenchAdd(Editor ed)
            sw.Start();
            var resbuf = new ResultBuffer();
                resbuf.Add(new TypedValue((int)DxfCode.Int32, i));
            sw.Stop();
            ed.WriteMessage($"\nElapsed milliseconds to add 50000 TypedValues: {sw.ElapsedMilliseconds}");
Gives:
Elapsed milliseconds to build from a TypedValues array: 18
Elapsed milliseconds to add 50000 TypedValues: 3734
Gilles Chanteau
GileCAD
GitHub
office
Nice solution.
Now I can save my large data using the ResultBuffer in 0.2 seconds instead of 12 seconds.
Thank you very much for the solution 🙂
