SendStringToExecute method problem
Yonas89
Yonas89
I'm trying to run a DIMLAYER command on AutoCAD. After I put a layer name it does not execute.
I run this line:
 Application.DocumentManager.MdiActiveDocument.SendStringToExecute("._DIMLAYER 0 ", True, False, False)
but I end up with this:
 Also, I tried to use Editor.command method, bet all i get is einvalidInput error.
Application.DocumentManager.MdiActiveDocument.Editor.Command("DIMLAYER", "0", "")
_gile
DIMLAYER is a system variable, you should use the Application.SetSystemVariable() method insted.
Application.SetSystemVariable("DIMLAYER", "0");
With SendStringtoExecute, as the command line is a string and the last command options (the layer name) is a string which may contain spaces, you have to validate the option with a newline character.
doc.SendStringToExecute("_.DIMLAYER 0\n", false, false, true);
With Editor.Command, you do not need to validate the layer name option with "".
ed.Command("_.DIMLAYER", "0");
Gilles Chanteau
GileCAD
GitHub
Yonas89
@_gile, thanks a lot for your reply. This was killing me... "\n" in sendStringtoExecute method did not help as I was still seeing "0\n" in the command line.  Ed.command method also still gives me einvalid input error. However using application.setsystemvariable method has worked!. Thank you so much!
