Jigging between two points
My requirement is like I have to get a block on cursor and move it only along x-axis between two points. As of now I am able to drag anywhere, instead of x-axis and between two points restriction. could you please give some reference on this.
Thanks in advance.
Tejaswini
_gile
Here's a simple example (just replace "blockName" with the block name).
        [CommandMethod("TEST")]
        public static void Test()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            using (var tr = db.TransactionManager.StartTransaction())
                var bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                if (!bt.Has("blockName"))
                    return;
                using (var br = new BlockReference(Point3d.Origin, bt["blockName"]))
                    br.TransformBy(ed.CurrentUserCoordinateSystem);
                    var jig = new BlockJig(br, Point3d.Origin, new Point3d(10.0, 0.0, 0.0));
                    var pr = ed.Drag(jig);
                    if (pr.Status == PromptStatus.OK)
                        var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                        curSpace.AppendEntity(br);
                        tr.AddNewlyCreatedDBObject(br, true);
                tr.Commit();
        class BlockJig : EntityJig
            BlockReference br;
            LineSegment3d line;
            Point3d dragPt;
            public BlockJig(BlockReference br, Point3d pt1, Point3d pt2) : base(br)
                this.br = br;
                line = new LineSegment3d(pt1, pt2);
            protected override SamplerStatus Sampler(JigPrompts prompts)
                var options = new JigPromptPointOptions("\nInsertion point: ");
                options.UserInputControls =
                    UserInputControls.Accept3dCoordinates |
                    UserInputControls.UseBasePointElevation;
                var result = prompts.AcquirePoint(options);
                if (result.Value.IsEqualTo(dragPt))
                    return SamplerStatus.NoChange;
                dragPt = result.Value;
                return SamplerStatus.OK;
            protected override bool Update()
                br.Position = line.GetClosestPointTo(dragPt).Point;
                return true;
Gilles Chanteau
GileCAD
GitHub
Thanks for the solution, It is very useful. But I am implementing using Drawjig instead of entityJig. Is there any equivalent method for Update in Drawjig as update method is not available in Drawjig class.
Thanks in advance.
                    return;
                tr.Commit();
            BlockReference br;
            LineSegment3d line;
            Point3d dragPt;
                this.br = br;
                return true;
                    return;
                tr.Commit();
            BlockReference br;
            LineSegment3d line;
            Point3d dragPt;
                this.br = br;
                return true;
