LINETYPE
LINETYPE
LINETYPE
Dear, is it possible to create a combobox in c# with line styles (see image)?
Best regards
norman.yuan
I am not aware of this kind of ready-to-use control available. If I were you, when there is need to ask user to select a line type on a custom UI, I would use a button beside a read-only text box (to show linetype name, but maybe a picture showing the line type image). Clicking the button would open the AutoCAD built-in LineType dialog as second level dialog. The AutoCAD LineType dialog can be found in Autodesk.AutoCAD.Windows.LineTypeDialog in acmgd.dll.
Norman Yuan
Drive CAD With Code
_gile
Here's a little example which displays the loaded line types.
    public struct Linetype
        public Linetype(string name, ObjectId id)
            Name = name;
            ObjectId = id;
        public string Name { get; }
        public ObjectId ObjectId { get; }
    public partial class Dialog : Form
        Linetype[] source;
        public Linetype Linetype => (Linetype)comboLinetypes.SelectedItem;
        public Dialog()
            InitializeComponent();
            // get the current database loaded line types
            var db = HostApplicationServices.WorkingDatabase;
            using (var tr = db.TransactionManager.StartOpenCloseTransaction())
                source = ((LinetypeTable)tr.GetObject(db.LinetypeTableId, OpenMode.ForRead))
                    .Cast<ObjectId>()
                    .Select(id => (LinetypeTableRecord)tr.GetObject(id, OpenMode.ForRead))
                    .Select(lt => new Linetype(lt.Name, lt.ObjectId))
                    .ToArray();
            // set the combo box binding and properties
            comboLinetypes.DropDownStyle = ComboBoxStyle.DropDownList;
            comboLinetypes.DataSource = source;
            comboLinetypes.DisplayMember = "Name";
            comboLinetypes.DrawMode = DrawMode.OwnerDrawFixed;
            comboLinetypes.DrawItem += ComboLinetypesnDrawItem;
        // draw the combo box items
        private void ComboLinetypesnDrawItem(object sender, DrawItemEventArgs e)
            if (e.Index > -1)
                var item = source[e.Index];
                var bounds = e.Bounds;
                int height = bounds.Height;
                int width = bounds.Width;
                Graphics graphics = e.Graphics;
                e.DrawBackground();
                graphics.DrawString(
                    item.Name,
                    e.Font,
                    new SolidBrush(e.ForeColor),
                    new Rectangle(bounds.Left, bounds.Top, 120, height));
                IntPtr iPtr = Autodesk.AutoCAD.Internal.Utils.DrawLineTypePattern(
                    item.ObjectId,
                    0, 0, width - 120, height);
                var img = System.Drawing.Image.FromHbitmap(iPtr);
                graphics.DrawImage(img, bounds.Left + 120, bounds.Top);
                e.DrawFocusRectangle();
Gilles Chanteau
GileCAD
GitHub
MassimilianoBaratta
Dear Gilles,
thank you for the previous collaboration.
Now, with the autocad 2019, the command  DrawLineTypePatter is replace with DrawLineType, but not work me.
the image is all black. Do you have a idea about?
Best regards
