Ribbon not loading on AutoCAD 2024
R.Gerritsen4967
Message 1 of 8
R.Gerritsen4967
I've been using my ribboncode for many versions of AutoCAD.
Last week I installed AutoCAD 2024 on my computer. Unfortunately, now my ribbon is not loading correctly.
I now use the following code to initialise the ribbon:
Public Class myRibbon
    Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
    Public Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
        Try
            AddHandler Autodesk.AutoCAD.ApplicationServices.Application.Idle, AddressOf App_Idle
        Catch ex As System.Exception
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            ed.WriteMessage(vbLf & "{0}", ex.ToString())
        End Try
    End Sub
    Private Sub App_Idle(sender As Object, e As EventArgs)
        RemoveHandler Autodesk.AutoCAD.ApplicationServices.Application.Idle, AddressOf App_Idle
        LoadRibbonPanels.LoadRibbon()
    End Sub
    Public Sub Terminate() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
    End Sub
End Class
Public Class LoadRibbonPanels
    <CommandMethod("Loadribbon")> Public Shared Sub LoadRibbon()
        'Create Ribbon tabs
        Dim ribbonControl1 As Autodesk.Windows.RibbonControl = Autodesk.Windows.ComponentManager.Ribbon
        If ribbonControl1 IsNot Nothing Then
            Dim Tab As RibbonTab = ribbonControl1.FindTab("myRibbon")
            If Tab IsNot Nothing Then
                ribbonControl1.Tabs.Remove(Tab)
            End If
            Tab = New RibbonTab With {
                .Title = "myRibbon",
                .Id = "1"
            'Add tab to the ribbon
            ribbonControl1.Tabs.Add(Tab)
            ' create Ribbon panels
        End If
    End Sub
End Class
As you can see I'm using the 'Application.Idle' event to load the ribbon on AutoCAD startup.
With all autocads up to 2023 this worked fine, but not in 2024.
It only works the first time I load the dll. After that the ribbon appears, but instantly disappears when a drawing is opened.
At first I was using the RibbonPaletteSetCreated event to load the ribbon, but, for now, this behaves the same as the Application.Idle event.
When I give the command 'LoadRibbon' the ribbons are displayed correctly. But I don't want to give this command everytime I start AutoCAD.
Does anyone know what I'm doing wrong?
Replies (7)
Message 2 of 8
Norman_Yuan
Your code ONLY load the custom ribbon tab when Acad becomes idle after startup (btw, you really should only remove the idle event handler inside the LoadRibbon() method, that is, only remove the event handler after the custom ribbon items are loaded
To keep the dynamically loaded custom ribbon items, you also need to handle RibbonPaletteSet.WorkspaceLoaded event to reload the custom ribbon items, when the current Workspace changes, which is what I suspect happens when you Acad 2024 starts.
Norman Yuan
Drive CAD With Code
Message 3 of 8
R.Gerritsen4967
@Norman_Yuan
Thank you! Adding the RibbonPaletteSet.WorkspaceLoaded event did the trick...
Message 4 of 8
AlexFielder
Hi @R.Gerritsen4967 @Norman_Yuan
Do you happen to have an example of using the RibbonServices.RibbonPaletteSet.WorkspaceLoaded event that you can share?
I have an addin I am writing that loads the ribbon when I debug, but when I build a release, the ribbon tab loads but isn't populated.
I have adapted this old RibbonHandler from over at The Swamp, but it just doesn't work, which, given it was written before these events changed (per this post)  is not really surprising:
public class RibbonHelper
        Action<RibbonControl> action = null;
        bool idleHandled = false;
        bool created = false;
        RibbonHelper(Action<RibbonControl> action)
            this.action = action ?? throw new ArgumentNullException("initializer");
            SetIdle(true);
        public static void OnRibbonFound(Action<RibbonControl> action)
            new RibbonHelper(action);
        private void SetIdle(bool value)
            if (value != idleHandled)
                if (value)
                    Application.Idle += Idle;
                else
                    Application.Idle -= Idle;
                idleHandled = value;
        private void Idle(object sender, EventArgs e)
            SetIdle(false); // Prevent re-entry
            if (!EnsureRibbonControl(action) && !created)
                created = true;
                RibbonServices.RibbonPaletteSetCreated += RibbonPaletteSetCreated;
        private void WorkspaceLoaded(object sender, EventArgs e)
            if (EnsureRibbonControl(action))
                // Once the ribbon is successfully created, no need to listen for WorkspaceLoaded
                RibbonServices.RibbonPaletteSet.WorkspaceLoaded -= WorkspaceLoaded;
        private bool EnsureRibbonControl(Action<RibbonControl> action)
            var ribbonControl = RibbonServices.RibbonPaletteSet?.RibbonControl;
            if (ribbonControl != null)
                action(ribbonControl);
                return true;
            return false;
        void RibbonPaletteSetCreated(object sender, EventArgs e)
            RibbonServices.RibbonPaletteSetCreated -= RibbonPaletteSetCreated;
            SetIdle(true);
Here is my initialization class:
public class Initialization : IExtensionApplication
        private static readonly log4net.ILog log = log4net.LogManager.GetLogger(System.Reflection.MethodBase.GetCurrentMethod().DeclaringType);
        private DocumentCollection _dwgManager = null;
        private static bool _handlerLoaded = false;
        //private static string _customCmd = null;
        private static ObjectId _selectedEntId = ObjectId.Null;
        private static CustomCommandMappers _customCommands = null;
        //private static bool _runCustomCommand = false;
        private static OptionsDlg _options = null;
        private static UXSettings uXSettings;
        private static List<MyButton> buttons = new List<MyButton>();
        public void Initialize()
            Document dwg = Application.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            _dwgManager = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
            uXSettings = new UXSettings();
            try
                CadApp.Idle += OnIdle;
                Application.DisplayingOptionDialog += new TabbedDialogEventHandler(Application_DisplayingOptionDialog);
                _dwgManager.DocumentActivated += new DocumentCollectionEventHandler(DwgManager_Activated);
                _dwgManager.DocumentBecameCurrent += new DocumentCollectionEventHandler(DwgManager_Activated);
                ed.WriteMessage("\nInitializing {0}...", this.GetType().Name);
                RibbonHelper.OnRibbonFound(SetupRibbon);
            catch (System.Exception ex) when (Commands.NotDebugging)
                ed.WriteMessage("failed:\n{0}", ex.ToString());
                log.Error(ex.ToString());
            RibbonHelper.OnRibbonFound(this.SetupRibbon);
        private void SetupRibbonByCUI(string tabName, string panelName)
            var cuiFile = CadApp.GetSystemVariable("MENUNAME");
            var cs = new Autodesk.AutoCAD.Customization.CustomizationSection(cuiFile.ToString() + @".cuix");
            var currWorkspace = (string)CadApp.GetSystemVariable("WSCURRENT");
            Autodesk.AutoCAD.Customization.RibbonRoot root = cs.MenuGroup.RibbonRoot;
            Autodesk.AutoCAD.Customization.RibbonPanelSourceCollection panels = root.RibbonPanelSources;
            Autodesk.AutoCAD.Customization.RibbonPanelSource panelsrc=new Autodesk.AutoCAD.Customization.RibbonPanelSource(root)
                Name = panelName,
                Text = panelName
            panelSrc.ElementID = panelSrc.Id = panelSrc.Name + "_PanelSourceID";
            panels.Add(panelSrc);
            Autodesk.AutoCAD.Customization.RibbonTabSource ribbonTabSource = new Autodesk.AutoCAD.Customization.RibbonTabSource(root)
                Name = tabName,
                Text = tabName
            ribbonTabSource.ElementID = ribbonTabSource.Id = ribbonTabSource.Name + "_TabSourceID";
            root.RibbonTabSources.Add(ribbonTabSource);
            Autodesk.AutoCAD.Customization.RibbonPanelSourceReference panelSrcRef = new Autodesk.AutoCAD.Customization.RibbonPanelSourceReference(ribbonTabSource)
                PanelId = panelSrc.ElementID
            ribbonTabSource.Items.Add(panelSrcRef);
            Autodesk.AutoCAD.Customization.WSRibbonTabSourceReference wsRibbonTabSourceRef = Autodesk.AutoCAD.Customization.WSRibbonTabSourceReference.Create(ribbonTabSource);
            int curWsIndex = cs.Workspaces.IndexOfWorkspaceName(currWorkspace);
            Autodesk.AutoCAD.Customization.WSRibbonRoot wsRibbonRoot = cs.Workspaces[curWsIndex].WorkspaceRibbonRoot;
            //Set the owner of the ribbon tab source reference and add it to the workspace ribbon tab collection
            wsRibbonTabSourceRef.SetParent(wsRibbonRoot);
            wsRibbonRoot.WorkspaceTabs.Add(wsRibbonTabSourceRef);
            BuildButtonsFromCommandMethods();
            Autodesk.AutoCAD.Customization.MacroGroup macroGroup = cs.MenuGroup.MacroGroups[0];
            Autodesk.AutoCAD.Customization.RibbonRow ribbonRow = panelSrc.AddNewRibbonRow();
            foreach (var btn in buttons)
                Autodesk.AutoCAD.Customization.MenuMacro btnMacro = macroGroup.CreateMenuMacro($"{btn.Text}_Macro", $"^C^C{btn.Command}", btn.Tag.ToString(), btn.Help,
                                                            Autodesk.AutoCAD.Customization.MacroType.Any, btn.SmallIcon.ToString(), btn.LargeIcon.ToString(), btn.Label);
                Autodesk.AutoCAD.Customization.RibbonCommandButton ribbonCommandButton = new Autodesk.AutoCAD.Customization.RibbonCommandButton(ribbonRow)
                    MacroID = btnMacro.ElementID,
                    ButtonStyle = Autodesk.AutoCAD.Customization.RibbonButtonStyle.LargeWithText,
                    KeyTip = btn.Text,
                    Text = btn.Text,
                    TooltipTitle = btn.Tooltip
                ribbonRow.Items.Add(ribbonCommandButton);
                Autodesk.AutoCAD.Customization.RibbonSeparator ribbonSeparator = new Autodesk.AutoCAD.Customization.RibbonSeparator(ribbonRow);
                ribbonSeparator.SeparatorStyle = Autodesk.AutoCAD.Customization.RibbonSeparatorStyle.Line;
                ribbonRow.Items.Add(ribbonSeparator);
                //ribbonRow.AddNewButton(btn.Text,
                //                        btn.Label,
                //                        btn.Command,
                //                        btn.Tooltip,
                //                        btn.SmallIcon.ToString(),
                //                        btn.LargeIcon.ToString(),
                //                        Autodesk.AutoCAD.Customization.RibbonButtonStyle.LargeWithText);
            cs.Save();
        private void SetupRibbon(RibbonControl control)
            var doc = CadApp.DocumentManager.MdiActiveDocument;
            var ed = doc.Editor;
            if (uXSettings.RibbonEnabled)
                RibbonControl ribbon = ComponentManager.Ribbon;
                if (ribbon != null)
                    RibbonTab tab = ribbon.FindTab("Stainless UK_Id");
                    if (tab != null)
                        ribbon.Tabs.Remove(tab);
                    BuildRibbonTabAndPanel("Stainless UK", "Masonry Support");
                else
                    ed.WriteLine("Ribbon not found, maybe AutoCAD is not idle yet..?");
        private RibbonControl BuildRibbonTabAndPanel(string tabName, string panelName)
            Autodesk.Windows.RibbonControl ribbon = ComponentManager.Ribbon;
            if (ribbon != null)
                RibbonTab rtab = new RibbonTab
                    Title = tabName,
                    Id = $"{tabName}_Id",
                    Name = tabName
                rtab.Panels.Add(AddOnePanel(panelName));
                ribbon.Tabs.Add(rtab);
            return ribbon;
        private void BuildButtonsFromCommandMethods()
            if (doc == null) return;
            var asm = Assembly.GetExecutingAssembly();
            var type = asm.GetType("CADLibraryMSA.Commands");
            if (type == null)
                ed.WriteMessage("\nCould not find the Commands class.");
                return;
            foreach (var m in type.GetMethods())
                foreach (CustomAttributeData attr in m.CustomAttributes)
                    if (attr.AttributeType.Name == "ButtonMethod")
                        GetSettingFromUXSettings(attr, "Text", out string btnText);
                        GetSettingFromUXSettings(attr, "ToolTip", out string cmdToolTip);
                        MyButton btn = new MyButton(attr.GetAttributeValue<string>("Command"),
                                                    btnText,
                                                    attr.GetAttributeValue<string>("Help"),
                                                    attr.GetAttributeValue<string>("Tag"),
                                                    attr.GetAttributeValue<Bitmap>("SmallIcon"),
                                                    attr.GetAttributeValue<Bitmap>("LargeIcon"),
                                                    $"{attr.GetAttributeValue<string>("Label")}_Id",
                                                    cmdToolTip, attr.GetAttributeValue<int>("ButtonOrder"));
                        //btn.Text = btn.Command;
                        btn.Click += (s, e) =>
                            var b2 = (Button)s;
                            var m2 = type.GetMethod(b2.Text);
                            if (m2 != null)
                                var res = m2.Invoke(this, null);
                        buttons.Add(btn);
        private static void GetSettingFromUXSettings(CustomAttributeData attr, string v, out string btnText)
            btnText = attr.GetAttributeValue<string>(v);
            string pattern = @"uXSettings\.(\w+)";
            if (btnText.Contains("uXSettings"))
                if (Regex.Matches(btnText, pattern).Count > 0)
                    var matches = Regex.Matches(btnText, pattern);
                    PropertyInfo prop = uXSettings.GetType().GetProperty(matches[0].Groups[1].Value);
                    string replacement = prop.GetValue(uXSettings).ToString();
                    btnText = Regex.Replace(btnText, @"uXSettings\.(\w+)", replacement);
        static RibbonPanel AddOnePanel(string panelName)
            RibbonButton rb;
            Version version = System.Reflection.Assembly.GetExecutingAssembly().GetName().Version;
            RibbonPanelSource rps = new RibbonPanelSource
                Title = panelName + $" - v{version}",
                Id = $"{panelName}_Id",
                Name = panelName
            RibbonPanel rp = new RibbonPanel
                Source = rps
            var sortedButtons = buttons.OrderBy(x => x.ButtonOrder).ToList();
            foreach (var btn in sortedButtons)
                //MenuMacro menuMacro = macroGroup.CreateMenuMacro($"{btn.Text}_Macro", $"^C^C{btn.Command}", btn.Tag.ToString(), btn.Help, MacroType.Any, btn.SmallIcon.ToString(), btn.LargeIcon.ToString(), btn.Label);
                //ribButton.MacroID = menuMacro.ElementID;
                rb = new RibbonButton
                    CommandParameter = btn.Command,
                    CommandHandler = new RibbonCommandHandler(),
                    Text = btn.Text,
                    HelpTopic = btn.Help,
                    Tag = btn.Tag,
                    Name = btn.Label,
                    ToolTip = btn.Tooltip,
                    ShowText = true,
                    ShowImage = true,
                    IsToolTipEnabled = true,
                    IsEnabled = true,
                    IsVisible = true,
                    Size = RibbonItemSize.Large,
                    ResizeStyle = RibbonItemResizeStyles.HideText,
                    Orientation = System.Windows.Controls.Orientation.Vertical
                var smallImage = LoadImage(btn.SmallIcon);
                var largeImage = LoadImage(btn.LargeIcon);
                if (smallImage != null)
                    rb.Image = smallImage;
                if (largeImage != null)
                    rb.LargeImage = largeImage;
                ed.WriteLine($"Added: {rb.Text} button");
                rps.Items.Add(rb);
                RibbonSeparator ribbonSeparator = new RibbonSeparator();
                ribbonSeparator.SeparatorStyle = RibbonSeparatorStyle.Line;
                rps.Items.Add(ribbonSeparator);
            //Create a Command Item that the Dialog Launcher can use,
            // for this test it is just a place holder.
            //RibbonButton rci = new RibbonButton();
            //rci.Name = "TestCommand";
            ////assign the Command Item to the DialgLauncher which auto-enables
            //// the little button at the lower right of a Panel
            //rps.DialogLauncher = rci;
            //rb = new RibbonButton();
            //rb.Name = "Test Button";
            //rb.ShowText = true;
            //rb.Text = "Test Button";
            ////Add the Button to the Tab
            //rps.Items.Add(rb);
            return rp;
        private static BitmapImage LoadImage(Bitmap imageToLoad)
            Bitmap pic = imageToLoad;
            MemoryStream ms = new MemoryStream();
            pic.Save(ms, ImageFormat.Png);
            BitmapImage bi = new BitmapImage();
            bi.BeginInit();
            bi.StreamSource = ms;
            bi.EndInit();
            return bi;
        private void Application_DisplayingOptionDialog(object sender, TabbedDialogEventArgs e)
            if (_options == null)
                _options = new OptionsDlg(uXSettings);
            if (uXSettings == null)
                _options.DataContext = uXSettings;
            _options.Resources = new ResourceDictionary() { Source = new Uri("pack://application:,,,/CADLibraryMSA;component/Themes/LightTheme.xaml") }; // Set the resource dictionary to the LightTheme.xaml file
            TabbedDialogExtension tde = new TabbedDialogExtension
                _options,
                new TabbedDialogAction(OnOK),
                new TabbedDialogAction(OnCancel),
                new TabbedDialogAction(OnHelp),
                new TabbedDialogAction(OnApply)
            e.AddTab("CAD Library Masonry Support Options", tde);
        private static void OnOK()
            ButtonPressedMessage("OK");
            SaveSettings();
        private static void OnCancel()
            uXSettings = null;
            ButtonPressedMessage("Cancel");
        private static void OnHelp()
            ButtonPressedMessage("Help");
        private static void OnApply()
            ButtonPressedMessage("Apply");
            SaveSettings();
        private static void ButtonPressedMessage(string name)
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            ed.WriteMessage("The {0} button was pressed.\n", name);
        private static void SaveSettings()
            if (_options != null)
                if (uXSettings != null)
                    uXSettings.Save();
        private void DwgManager_Activated(object sender, DocumentCollectionEventArgs e)
            //if the document is not null, then we need to build the UI
            if (e.Document != null)
                if (uXSettings.EnableDoubleClickSystemEditing)
                    AppDoubleClickHandler appDoubleClickHandler = new AppDoubleClickHandler();
                    Application.SetSystemVariable("DBLCLKEDIT", 0);
                    AppDoubleClickHandler.AddDoubleClickHandler();
                else
                    Application.SetSystemVariable("DBLCLKEDIT", 1);
                    AppDoubleClickHandler.RemoveDoubleClickHandler();
        private void OnIdle(object sender, EventArgs e)
            if (doc != null)
                CadApp.Idle -= OnIdle;
                //RibbonHelper.OnRibbonFound(SetupRibbon);
                doc.Editor.WriteMessage("\nCADLibraryMSA loaded.\n");
        public void Terminate()
            _dwgManager.DocumentActivated -= new DocumentCollectionEventHandler(DwgManager_Activated);
            Application.DisplayingOptionDialog -= new TabbedDialogEventHandler(Application_DisplayingOptionDialog);
Any help greatly appreciated as I am losing my wits over this. 😞
Alex.
Message 5 of 8
R.Gerritsen4967
@AlexFielder ,
This is my code to initialize a ribbon:
Public Class GSRibbon
        Try
            ed.WriteMessage(vbLf & "Loading ribbon failed:")
        End Try
    End Sub
        GSRibbonPanels.GSRibbon()
        AddHandler Autodesk.AutoCAD.Ribbon.RibbonServices.RibbonPaletteSet.WorkspaceLoaded, AddressOf Workspace_Loaded
    End Sub
    Private Sub Workspace_Loaded(sender As Object, e As EventArgs)
    End Sub
    End Sub
End Class
GSRibbonPanels.GSRibbon() is where I create my ribbonpanels.
I'm sorry this is in Visual Basic😁. I just can't get used to C#.
Hope this helps!
Message 6 of 8
AlexFielder
I appreciate the reply, no matter that it is in VB. 🙂
After posting I moved one thing in my code and lo and behold the ribbon now displays reliably.
For future-me's sake, here is the  one part of initialization.cs that I changed to get mine to work:
            if (doc != null)
                RibbonHelper.OnRibbonFound(SetupRibbon); // < uncommented this line
Message 7 of 8
joseguiaCES
" .. future me sake .." thats funny
replying to keep this topic and code handy, thank you both for sharing. 😃
Message 8 of 8
AlexFielder
It's funny because it is true lol - I have lost count the number of times I have hit upon a problem that I have already solved some other time but forgotten about the solution and ended up back in these forums reading my own words.
