why this dynamo code not working for autocad?
thsa2501
thsa2501
hii everyone,
i try to sort numbers for attribute blocks via polyline vertex but it does not work.
this code is from one of the youtube channel his name "Khasan Mamaev".
i attached dynamo code and drawing.
if not understand what am i trying to say, kindly watch https://youtu.be/K5pjPOcFl6A.
thanks, advance
best regards
hussain
it popup message it has no attribute for active documentit popup message it has no attribute for active document
hosneyalaa
hi
try
# Blocks numerator
# ©2017, Khasan Mamaev
# www.dynamobim.ru
if IN[0] != True: off = 1/0
tagARK = IN[1]
scale = float(IN[2])
r = 250.0 * scale/100
rev = IN[3]
import clr
from operator import itemgetter
import re
import System
clr.AddReference('ProtoGeometry')
import Autodesk
from Autodesk.DesignScript.Geometry import *
DPoint = Autodesk.DesignScript.Geometry.Point
app = System.Runtime.InteropServices.Marshal.GetActiveObject("Autocad.Application")
AcDoc = app.ActiveDocument
AcDoc.SendCommand("(SSGET\"_x\"'((-4 . \"<OR\")(0 . \"*TEXT,*Polyline\")(-4 . \"<AND\")(0 . \"INSERT\")(66 . 1)(-4 . \"AND>\")(-4 . \"OR>\"))) ")
AcDoc.SendCommand("SELECT (SSGET\"_p\")  ")
sset = AcDoc.PickfirstSelectionSet
def ptD(p):
	return DPoint.ByCoordinates(p[0],p[1],p[2])
def vertex(pl):
	pts = []
	for i,k in enumerate(pl):
		if i%2 == 0:
			pts.append(DPoint.ByCoordinates(k, pl[i+1], 0.0))
	return pts
def cir(p,r):
	return Circle.ByCenterPointRadius(p,r)
blocks = []
circs = []
RRR = []
for j in sset:
	if j.ObjectName == 'AcDbPolyline':
		poly = j
		#RRR.append(j)
	elif j.ObjectName == 'AcDbBlockReference':
		attr = j.GetAttributes()
		#RRR.append(j)
		for i in attr:
		    #RRR.append( i.TagString )
		    if i.TagString != tagARK:
		       p = ptD(j.InsertionPoint)
		       blocks.append([j, cir(p,r)])
		       circs.append(cir(p,r))
		    elif i.TagString == tagARK:
		         arknum = re.sub("\D", "", i.TextString)
		         RRR.append( arknum )
		         ark = i
acPoints = poly.Coordinates
pline = PolyCurve.ByPoints(vertex(acPoints))
OUT = pline
thsa2501
hi
thanks for the message.it does not work for me.i attached image the message popup when i trying to run.kindly solve me.i am using autocad 2024 and dynamo sandbox.
kinldy make a video to understand this.
hosneyalaa
I think the error is because
Opening two Autocad files
It is preferable to use dynamo through civil 3 d If possible you have There are options Easier, better and faster
Or in this method you must have knowledge of using Object Model (ActiveX)
thsa2501
hi,
ok i will try to using civil 3d,but i would like to know. how it works dynamo only in autocad for him.
hosneyalaa
TRY
@thsa2501
# Blocks numerator
# www.dynamobim.ru
import clr
import re
import System
import Autodesk
def ptD(p):
def vertex(pl):
	pts = []
		if i%2 == 0:
	return pts
def cir(p,r):
blocks = []
circs = []
RRR = []
for j in sset:
		poly = j
		#RRR.append(j)
OUT = acPoints
# Blocks numerator
# www.dynamobim.ru
import clr
import re
import System
import Autodesk
tagARK = IN[0]
blocks = []
circs = []
RRR = []
for j in sset:
		poly = j
		#RRR.append(j)
		#RRR.append(j)
		for i in attr:
		         ark = i
OUT = RRR
