Update Viewport with database is not working.
cstotal_Autodesk
cstotal_Autodesk
I have no idea why after I work with vb.net with database, zoom of current view is changing.
so I want zoom extent the document without open document in editor, only database.readdwgfile
I found some code on .net forum but I guess it doesn't work.
Dim originalDB As Database = HostApplicationServices.WorkingDatabase
        Using AcadDB As New Database(False, True)
            AcadDB.ReadDwgFile(OldDwgFilePath, FileOpenMode.OpenForReadAndAllShare, False, Nothing)
            HostApplicationServices.WorkingDatabase = AcadDB
            If AcadDB.TileMode = True Then 'Model
                Using Trans As Transaction = AcadDB.TransactionManager.StartTransaction
                    Dim vpt As ViewportTable = Trans.GetObject(AcadDB.ViewportTableId, OpenMode.ForRead)
                    Dim vptr As ViewportTableRecord = Trans.GetObject(AcadDB.CurrentViewportTableRecordId, OpenMode.ForWrite)
                    vptr.CenterPoint = New Point2d(1000, 1000)
                    vptr.Height = 2000
                    vptr.Width = 2000
                    AcadDB.UpdateExt(True)
                End Using
            ZoomExtents_DB_2(AcadDB)
            AcadDB.SaveAs(NewDwgFilePath, DwgVersion.Current)
            HostApplicationServices.WorkingDatabase = originalDB
        End Using
what actual code I used, include calculate for zoom extent but I changed it for fixed number for testing view is changed so I changed it as real numbers and it doesn't work(also not working with calculated numbers obviously)
How can I change current views zoom without open in editor?
cstotal_Autodesk
I just found if I saveas database when
HostApplicationServices.WorkingDatabase = dwgfile Database
It changes Zoom as Auto. so before saveas
changed HostApplicationServices.WorkingDatabase to origin database
kerry_w_brown
Did you try committing the transaction ?
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
cstotal_Autodesk
oh Yes. as I wrote on reply myself, it was solved. thank for replying.
JamesMaeding
I just rediscovered this after 2 hours of troubleshooting.
In my experience, only set HostApplicationServices.WorkingDatabase to side database while touching system vars using AcAp.SetSystemVariable() method.
I am not dealing with viewports though, just modelspace.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
