Make a button and a toolbar of a custom command loaded in a .dll file
Hi, im new with vb.net and i made some commands that runs well when i loaded with NETLOAD command.
The problem is that i want to improve it making a button (i found that is called a ribbon button)to each command in a toolbar; also i need to know hoy to make that toolbar that loads when y load the .dll file. i read a lot of related topics in this forum and also in another pages but i cant find an a definitve answer or procedure, which assemblies or libraries i need to import.
Thanks for your help
marcin.sachs
You have two options:
1. Create standard cuix file
2. Create custom ribbon using code (without cuix)
The second option perfect work for me.
The first you need create ribbon. My ribbon class:
public class Ribbon
        public Ribbon()
        public static void CreateMyRibbon()
            if (Autodesk.Windows.ComponentManager.Ribbon == null)
                //    //load the custom Ribbon on startup, but at this point
                //    //the Ribbon control is not available, so register for
                //    //an event and wait
                Autodesk.Windows.ComponentManager.ItemInitialized +=
                    new EventHandler<RibbonItemEventArgs>
                      (ComponentManager_ItemInitialized);
            else
                //    //the assembly was loaded using NETLOAD, so the ribbon
                //    //is available and we just create the ribbon
                CreateRibbon();
        private static void ComponentManager_ItemInitialized(object sender, RibbonItemEventArgs e)
            //now one Ribbon item is initialized, but the Ribbon control
            //may not be available yet, so check if before
            if (Autodesk.Windows.ComponentManager.Ribbon != null)
                //ok, create Ribbon
                CreateRibbon();
                //and remove the event handler
                Autodesk.Windows.ComponentManager.ItemInitialized -=
        public static void CreateRibbon()
            Autodesk.Windows.RibbonControl ribbonControl = Autodesk.Windows.ComponentManager.Ribbon;
            List<string> tabs = new List<string>();
            foreach (Autodesk.Windows.RibbonTab tab in ribbonControl.Tabs)
               tabs.Add(tab.Title);
            if (tabs.Contains("My Ribbon") == false)
                RibbonTab Tab = new RibbonTab();
                Tab.Title = "My Ribbon";
                Tab.Id = "My_Ribbon_TAB_ID";
                ribbonControl.Tabs.Add(Tab);
                // create Ribbon panels
                Autodesk.Windows.RibbonPanelSource visibilityPanel = new RibbonPanelSource();
                visibilityPanel.Title = "Visibility";
                RibbonPanel VisibilityPanel = new RibbonPanel();
                VisibilityPanel.Source = visibilityPanel;
                Tab.Panels.Add(VisibilityPanel);
                RibbonButton UpdateDrawingTable = new RibbonButton();
                UpdateDrawingTable.Text = "Update Drawing Table";
                UpdateDrawingTable.Description = "Update Drawing Table";
                UpdateDrawingTable.ShowText = true;
                UpdateDrawingTable.ShowImage = true;
                UpdateDrawingTable.Image = Images.getBitmap(Properties.Resources.Small);
                UpdateDrawingTable.LargeImage = Images.getBitmap(Properties.Resources.large);
                UpdateDrawingTable.Orientation = System.Windows.Controls.Orientation.Vertical;
                UpdateDrawingTable.Size = RibbonItemSize.Large;
                UpdateDrawingTable.CommandHandler = new RibbonCommandHandler();
                UpdateDrawingTable.CommandParameter = "KCT_UpdatedrawingTable";
                RibbonButton ShowGroundFloorButton = new RibbonButton();
                ShowGroundFloorButton.Text = "Ground Floor";
                ShowGroundFloorButton.Description = "Show Ground Floor Level";
                ShowGroundFloorButton.ShowText = true;
                ShowGroundFloorButton.ShowImage = false;
                ShowGroundFloorButton.CommandHandler = new SplitButtonCommandHandler();
                ShowGroundFloorButton.CommandParameter = "KTC_ShowGroundFloorLevel";
                RibbonButton ShowFirstFloorButton = new RibbonButton();
                ShowFirstFloorButton.Text = "First Floor";
                ShowFirstFloorButton.Description = "Show First Floor Level";
                ShowFirstFloorButton.ShowText = true;
                ShowFirstFloorButton.ShowImage = false;
                ShowFirstFloorButton.CommandHandler = new SplitButtonCommandHandler();
                ShowFirstFloorButton.CommandParameter = "KTC_ShowFirstFloorLevel";
                RibbonButton ShowAllLevelsButton = new RibbonButton();
                ShowAllLevelsButton.Text = "All Levels";
                ShowAllLevelsButton.Description = "Show All Levels";
                ShowAllLevelsButton.ShowText = true;
                ShowAllLevelsButton.ShowImage = false;
                ShowAllLevelsButton.CommandHandler = new SplitButtonCommandHandler();
                ShowAllLevelsButton.CommandParameter = "KTC_ShowAllLevels";
                RibbonSplitButton showLevelCombo = new RibbonSplitButton();
                showLevelCombo.Text = "RibbonSplitButton";
                showLevelCombo.ShowText = true;
                showLevelCombo.Items.Add(ShowAllLevelsButton);
                showLevelCombo.Items.Add(ShowGroundFloorButton);
                showLevelCombo.Items.Add(ShowFirstFloorButton);
                showLevelCombo.Current = ShowAllLevelsButton;
                RibbonRowPanel VisibilityPanelRow = new RibbonRowPanel();
                VisibilityPanelRow.Items.Add(showLevelCombo);
                //visibilityPanel.Items.Add(UpdateDynamicBlocks);
                visibilityPanel.Items.Add(UpdateDrawingTable);
                visibilityPanel.Items.Add(VisibilityPanelRow);
                Tab.IsActive = false;
        public class RibbonCommandHandler : System.Windows.Input.ICommand
            public bool CanExecute(object parameter)
                return true;
            public event EventHandler CanExecuteChanged;
            public void Execute(object parameter)
                Document doc = acadApp.DocumentManager.MdiActiveDocument;
                if (parameter is RibbonButton)
                    RibbonButton button = parameter as RibbonButton;
                    Document dwg = Application.DocumentManager.MdiActiveDocument;
                    dwg.SendStringToExecute((string)button.CommandParameter + " ", true, false, true);
        public class SplitButtonCommandHandler : System.Windows.Input.ICommand
                return true;
                    Type type = typeof(ClassWithCommand);
                    MethodInfo method = type.GetMethod((string)button.CommandParameter);
                    ClassWithCommand classWithCommand= new ClassWithCommand();
                    string result = (string)method.Invoke(kingspanCADTools, null);
                    Console.WriteLine(result);
        public class Images
            public static BitmapImage getBitmap(Bitmap image)
                MemoryStream stream = new MemoryStream();
                image.Save(stream, ImageFormat.Png);
                BitmapImage bmp = new BitmapImage();
                bmp.BeginInit();
                bmp.StreamSource = stream;
                bmp.EndInit();
                return bmp;
to load when the dllis loaded you can add to initialize:
public void Initialize()
CreateMyRibbon();
