XCLIP - No Boundary Found
I'm attempting to XCLIP an External Reference DWG. The code appears to work, except for AutoCAD recognizing it. If I press the Remove Clipping Boundary from the ribbon, AutoCAD indicates "No clip boundary found." I have to create a new clipping boundary to remove the clipping boundary added via code.
I'm using code based on this blog post:
Is this a known issue or is there a method that gives the expected results.
Using AutoCAD Civil 3D 2020.
public static bool AddXClip(Transaction tr, List<Point2d> points)
var doc = Application.DocumentManager.MdiActiveDocument;
var db = doc.Database;
var ed = doc.Editor;
var typVals = new List<TypedValue>
new TypedValue((int)DxfCode.Operator, "<OR"),
new TypedValue((int)DxfCode.Start, typeof(BlockReference)),
new TypedValue((int)DxfCode.Start, "INSERT"),
new TypedValue((int)DxfCode.Operator, "OR>")
var xrefObjId = ed.GetEntityByTypes(typVals, "Select external reference to XCLIP: ", "", out Point3d pickPt);
if (xrefObjId.IsNull)
return false;
try
var pt2DCollection = new Point2dCollection();
foreach (var pt in points)
pt2DCollection.Add(pt);
var acFilterDictName = "ACAD_FILTER";
var acSpatialName = "SPATIAL";
var blkRef = xrefObjId.GetObject(OpenMode.ForWrite) as BlockReference;
var acSpatialFilterDef = new SpatialFilterDefinition(pt2DCollection, blkRef.Normal, 0.0, 0.0, 0.0, true);
var acSpatialFilter = new SpatialFilter { Definition = acSpatialFilterDef };
if (blkRef.ExtensionDictionary.IsNull)
blkRef.CreateExtensionDictionary();
var extensionDict = blkRef.ExtensionDictionary.GetObject(OpenMode.ForWrite) as DBDictionary;
if (extensionDict.Contains(acFilterDictName))
var filterDict = extensionDict.GetAt(acFilterDictName).GetObject(OpenMode.ForWrite) as DBDictionary;
if (filterDict.Contains(acSpatialName))
filterDict.Remove(acSpatialName);
filterDict.SetAt(acSpatialName, acSpatialFilter);
else
var filterDict = new DBDictionary();
extensionDict.SetAt(acFilterDictName, filterDict);
tr.AddNewlyCreatedDBObject(filterDict, true);
tr.AddNewlyCreatedDBObject(acSpatialFilter, true);
return true;
catch (System.Exception ex)
return false;
Thanks!
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
