Jigging a polyline extrusion
dpayton
dpayton
I am trying to create a command that will let me place a polyline of a set shape and then extrude it along a path with custom keyword options. In testing to figure out how to do it I have run into two problems. The most important one to me is that the Jig to extrude dose not render the graphics while selecting a point. Though the solid is created correctly once the point is picked. What am I missing? How do I get the extrusion to render while picking the point?
The less important problem is that I am using two jigs. I am using a DrawJig to place the polyline, then I am using an EntityJig to extrude the solid. Is there a way to combine these both into one jig. So do both in a DrawJig or both in and EntityJig?
[CommandMethod("SolidJig")]
        public static void SolidJig()
            Editor ed = acApp.DocumentManager.MdiActiveDocument.Editor;
            Database db = ed.Document.Database;
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    JigPline jig = new JigPline();
                    Point3dCollection pts;
                    PromptResult res = jig.DragMe(out pts);
                    if (res.Status == PromptStatus.OK)
                        BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                        Polyline3d pLine = new Polyline3d(Poly3dType.SimplePoly, pts, true);
                        DBObjectCollection dbObj = new DBObjectCollection();
                        dbObj.Add(pLine);
                        Region region = Region.CreateFromCurves(dbObj)[0] as Region;
                        btr.AppendEntity(region);
                        tr.AddNewlyCreatedDBObject(region, true);
                        Solid3d solid = new Solid3d();
                        btr.AppendEntity(solid);
                        tr.AddNewlyCreatedDBObject(solid, true);
                        JigSolid solJig = new JigSolid(solid, ed.CurrentUserCoordinateSystem, region, pts[0]);
                        btr.AppendEntity(pLine);
                        tr.AddNewlyCreatedDBObject(pLine, true);
                        res = ed.Drag(solJig);
                        switch (res.Status)
                            case PromptStatus.OK:
                                break;
                    tr.Commit();
            catch { }
        public class JigPline : DrawJig
            public Point3d startPt;
            public Point3dCollection pts;
            public PromptResult DragMe(out Point3dCollection o_pnts)
                while (true)
                    PromptResult jigRes = ed.Drag(this);
                    if (jigRes.Status != PromptStatus.Keyword)
                        o_pnts = pts;
                        return jigRes;
            protected override SamplerStatus Sampler(JigPrompts prompts)
                JigPromptPointOptions pointOpts = new JigPromptPointOptions();
                pointOpts.Keywords.Add("Insertion");
                pointOpts.UserInputControls = (UserInputControls.Accept3dCoordinates | UserInputControls.NullResponseAccepted);
                pointOpts.Message = "\nSelect start point";
                PromptPointResult jigRes = prompts.AcquirePoint(pointOpts);
                Point3d pt = jigRes.Value;
                if (pt == startPt)
                    return SamplerStatus.NoChange;
                startPt = pt;
                if (jigRes.Status == PromptStatus.OK || jigRes.Status == PromptStatus.Keyword)
                    return SamplerStatus.OK;
                return SamplerStatus.Cancel;
            protected override bool WorldDraw(Autodesk.AutoCAD.GraphicsInterface.WorldDraw draw)
                pts = new Point3dCollection();
                pts.Add(startPt + new Vector3d(-3, 0, 0));
                pts.Add(startPt + new Vector3d(3, 0, 0));
                pts.Add(startPt + new Vector3d(3, 0, 6));
                pts.Add(startPt + new Vector3d(2.5 , 0, 6));
                pts.Add(startPt + new Vector3d(2.5, 0, 1));
                pts.Add(startPt + new Vector3d(-2.5 , 0, 1));
                pts.Add(startPt + new Vector3d(-2.5 , 0, 6));
                pts.Add(startPt + new Vector3d(-3, 0, 6));
                return draw.Geometry.Polygon(pts);
        public class JigSolid : EntityJig
            Matrix3d _ucs;
            Point3d _pt;
            Point3d _endPt;
            double _dist;
            Region _reg;
            Solid3d _sol;
            SweepOptions _swpOpts;
            Polyline _pLine = new Polyline();
            public JigSolid(Solid3d sol, Matrix3d ucs, Region region, Point3d insertionPt) : base(region)
                _ucs = ucs;
                _pt = insertionPt;
                _reg = region;
                _sol = sol;
                _swpOpts = new SweepOptions();
                JigPromptPointOptions ptOpts = new JigPromptPointOptions();
                ptOpts.UserInputControls = (UserInputControls.Accept3dCoordinates | UserInputControls.NoZeroResponseAccepted
                    | UserInputControls.GovernedByOrthoMode | UserInputControls.NoNegativeResponseAccepted);
                ptOpts.UseBasePoint = true;
                ptOpts.BasePoint = _pt;
                ptOpts.Cursor = CursorType.RubberBand;
                ptOpts.Message = "\nSpecify distance :";
                PromptPointResult ppr = prompts.AcquirePoint(ptOpts);
                if (ppr.Status == PromptStatus.OK)
                    Point3d tmp = ppr.Value.TransformBy(_ucs.Inverse());
                    if (tmp.DistanceTo(_pt) < Tolerance.Global.EqualPoint)
                _dist = _pt.DistanceTo(new Point3d(_pt.X, ppr.Value.Y, _pt.Z));
                _endPt = ppr.Value;
            protected override bool Update()
                try
                    //_sol.ExtrudeAlongPath(_reg, new Line(_pt, new Point3d(_pt.X, _endPt.Y + 20, _pt.Z))  , 0);
                    //_sol.Extrude(_reg, _dist, 0);
                    _sol.CreateExtrudedSolid(_reg, _pt.GetVectorTo(_endPt), _swpOpts);
                catch (System.Exception ex)
                    return false;
                return true;
dpayton
Using this post I was able to figure out how to move the polyline inside an entityjig using a PointMonitorEventHandler which answer one of my questions, however it created a new one. I am not very confident in my use of the PointMonitorEventHandler. Is inside the Sampler override the correct place to add and remove the handler, and will it get removed correctly the way I have written it?
public class RegionJig : EntityJig
        Region _reg;
        Point3d _basePoint;
        Point3d _currentPoint;
        Editor _ed;
        private void Editor_PointMonitor(object sender, PointMonitorEventArgs e)
            _currentPoint = e.Context.RawPoint;
        public RegionJig(Region region) : base(region)
            _reg = region;
            _ed = acApp.DocumentManager.MdiActiveDocument.Editor;
            try
                _ed.PointMonitor += new PointMonitorEventHandler(Editor_PointMonitor);
                pointOpts.UserInputControls = (UserInputControls.Accept3dCoordinates | UserInputControls.NoNegativeResponseAccepted | UserInputControls.NoZeroResponseAccepted);
                pointOpts.Message = "\nSelect insertion point: ";
                PromptPointResult pres = prompts.AcquirePoint(pointOpts);
                if (_basePoint.DistanceTo(pres.Value) < Tolerance.Global.EqualPoint)
                else
                    _currentPoint = pres.Value;
            catch (System.Exception e)
                throw;
            finally
                _ed.PointMonitor -= new PointMonitorEventHandler(Editor_PointMonitor);
            try
                _reg.TransformBy(Matrix3d.Displacement(_basePoint.GetVectorTo(_currentPoint)));
                _basePoint = _currentPoint;
            catch(System.Exception ex)
                return false;
            return true;
dpayton
Turns out the point monitor is unnecessary. I still have not had any luck figuring out how to render the extrusion, anyone have any advice?
            Region _reg;
            Point3d _basePoint;
            Editor _ed;
            Vector3d _baseVector;
            Vector3d _deltaVector;
            int _phase;
            Solid3d _solid;
            SweepOptions _swepOts;
            public RegionJig(Region region,Solid3d solid) : base(region)
                _reg = region;
                _solid = solid;
                _phase = 1;
                _swepOts = new SweepOptions();
                _baseVector = new Vector3d(1, 0, 0);
                try
                    PromptPointResult pointRes;
                    switch (_phase)
                        case 1:
                            pointRes = prompts.AcquirePoint(pointOpts);
                            if (pointRes.Status == PromptStatus.OK)
                                if (_basePoint.DistanceTo(pointRes.Value) < Tolerance.Global.EqualPoint)
                                _currentPoint = pointRes.Value;
                            else
                        case 2:
                            pointOpts.Message = "\nSelect direction: ";
                            pointOpts.Cursor = CursorType.RubberBand;
                            pointOpts.UseBasePoint = true;
                            pointOpts.BasePoint = _basePoint;
                                _deltaVector = new Vector3d(_basePoint.GetVectorTo(_currentPoint).X, _basePoint.GetVectorTo(_currentPoint).Y, 0);
                            else
                    throw;
                try
                    switch (_phase)
                        case 1:
                            break;
                        case 2:
                            _reg.TransformBy(Matrix3d.Rotation(_baseVector.GetAngleTo(_deltaVector, Vector3d.ZAxis), Vector3d.ZAxis, _basePoint));
                            _solid.CreateExtrudedSolid(_reg, _deltaVector, _swepOts);
                            _baseVector = _deltaVector;
                            break;
                    return false;
                return true;
            internal void NextPhase()
                _phase++;
            internal void RunTillComplete(Editor ed)
                try
                    while (true)
                        var res = ed.Drag(this);
                            if (_phase == 2)
                                return;
                            NextPhase();
                        else if (res.Status == PromptStatus.Cancel)
                            return;
                    throw;
dpayton
Figured it out, seems out the base needs to be the Solid3d not the Region. Like this:
            public RegionJig(Region region,Solid3d solid) : base(solid)
                _reg = region;
                _solid = solid;
                _phase = 1;
 Not this:
                _reg = region;
                _solid = solid;
                _phase = 1;
