- Mute
- Permalink
- Report
I am trying to create a command that will let me place a polyline of a set shape and then extrude it along a path with custom keyword options. In testing to figure out how to do it I have run into two problems. The most important one to me is that the Jig to extrude dose not render the graphics while selecting a point. Though the solid is created correctly once the point is picked. What am I missing? How do I get the extrusion to render while picking the point?
The less important problem is that I am using two jigs. I am using a DrawJig to place the polyline, then I am using an EntityJig to extrude the solid. Is there a way to combine these both into one jig. So do both in a DrawJig or both in and EntityJig?
[CommandMethod("SolidJig")]
public static void SolidJig()
Editor ed = acApp.DocumentManager.MdiActiveDocument.Editor;
Database db = ed.Document.Database;
try
using (Transaction tr = db.TransactionManager.StartTransaction())
JigPline jig = new JigPline();
Point3dCollection pts;
PromptResult res = jig.DragMe(out pts);
if (res.Status == PromptStatus.OK)
BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
Polyline3d pLine = new Polyline3d(Poly3dType.SimplePoly, pts, true);
DBObjectCollection dbObj = new DBObjectCollection();
dbObj.Add(pLine);
Region region = Region.CreateFromCurves(dbObj)[0] as Region;
btr.AppendEntity(region);
tr.AddNewlyCreatedDBObject(region, true);
Solid3d solid = new Solid3d();
btr.AppendEntity(solid);
tr.AddNewlyCreatedDBObject(solid, true);
JigSolid solJig = new JigSolid(solid, ed.CurrentUserCoordinateSystem, region, pts[0]);
btr.AppendEntity(pLine);
tr.AddNewlyCreatedDBObject(pLine, true);
res = ed.Drag(solJig);
switch (res.Status)
case PromptStatus.OK:
break;
tr.Commit();
catch { }
public class JigPline : DrawJig
public Point3d startPt;
public Point3dCollection pts;
public PromptResult DragMe(out Point3dCollection o_pnts)
while (true)
PromptResult jigRes = ed.Drag(this);
if (jigRes.Status != PromptStatus.Keyword)
o_pnts = pts;
return jigRes;
protected override SamplerStatus Sampler(JigPrompts prompts)
JigPromptPointOptions pointOpts = new JigPromptPointOptions();
pointOpts.Keywords.Add("Insertion");
pointOpts.UserInputControls = (UserInputControls.Accept3dCoordinates | UserInputControls.NullResponseAccepted);
pointOpts.Message = "\nSelect start point";
PromptPointResult jigRes = prompts.AcquirePoint(pointOpts);
Point3d pt = jigRes.Value;
if (pt == startPt)
return SamplerStatus.NoChange;
startPt = pt;
if (jigRes.Status == PromptStatus.OK || jigRes.Status == PromptStatus.Keyword)
return SamplerStatus.OK;
return SamplerStatus.Cancel;
protected override bool WorldDraw(Autodesk.AutoCAD.GraphicsInterface.WorldDraw draw)
pts = new Point3dCollection();
pts.Add(startPt + new Vector3d(-3, 0, 0));
pts.Add(startPt + new Vector3d(3, 0, 0));
pts.Add(startPt + new Vector3d(3, 0, 6));
pts.Add(startPt + new Vector3d(2.5 , 0, 6));
pts.Add(startPt + new Vector3d(2.5, 0, 1));
pts.Add(startPt + new Vector3d(-2.5 , 0, 1));
pts.Add(startPt + new Vector3d(-2.5 , 0, 6));
pts.Add(startPt + new Vector3d(-3, 0, 6));
return draw.Geometry.Polygon(pts);
public class JigSolid : EntityJig
Matrix3d _ucs;
Point3d _pt;
Point3d _endPt;
double _dist;
Region _reg;
Solid3d _sol;
SweepOptions _swpOpts;
Polyline _pLine = new Polyline();
public JigSolid(Solid3d sol, Matrix3d ucs, Region region, Point3d insertionPt) : base(region)
_ucs = ucs;
_pt = insertionPt;
_reg = region;
_sol = sol;
_swpOpts = new SweepOptions();
JigPromptPointOptions ptOpts = new JigPromptPointOptions();
ptOpts.UserInputControls = (UserInputControls.Accept3dCoordinates | UserInputControls.NoZeroResponseAccepted
| UserInputControls.GovernedByOrthoMode | UserInputControls.NoNegativeResponseAccepted);
ptOpts.UseBasePoint = true;
ptOpts.BasePoint = _pt;
ptOpts.Cursor = CursorType.RubberBand;
ptOpts.Message = "\nSpecify distance :";
PromptPointResult ppr = prompts.AcquirePoint(ptOpts);
if (ppr.Status == PromptStatus.OK)
Point3d tmp = ppr.Value.TransformBy(_ucs.Inverse());
if (tmp.DistanceTo(_pt) < Tolerance.Global.EqualPoint)
_dist = _pt.DistanceTo(new Point3d(_pt.X, ppr.Value.Y, _pt.Z));
_endPt = ppr.Value;
protected override bool Update()
try
//_sol.ExtrudeAlongPath(_reg, new Line(_pt, new Point3d(_pt.X, _endPt.Y + 20, _pt.Z)) , 0);
//_sol.Extrude(_reg, _dist, 0);
_sol.CreateExtrudedSolid(_reg, _pt.GetVectorTo(_endPt), _swpOpts);
catch (System.Exception ex)
return false;
return true;
