Installing AutoCAD Wizards to Visual Studio Community
I'm unable to install the AutoCAD wizards to Visual Studio Community. It gives me a message that I need to have Pro/Premium/Ultimate or Express versions installed. Sence Microsoft changed the name from Express to Community is there a way to install the wizards or will I be forced to use an older version of Visual Studio?
arcticad
We had a discussion about how to setup a project without the wizard.
http://forums.autodesk.com/t5/net/trying-to-get-started/td-p/5725975
let me  know if you have any questions.
(defun botsbuildbots() (botsbuildbots))
Ed__Jobe
If you go to www.autodesk.com/developautocad there is a set of tutorials down the page in the Learning section. Look for "Autocad 20## .Net Training" to download the zip file. The My First Plugin series at the top assumes you have the wizards installed, but the tutorials I pointed to show you how to start from scratch.
Ed
How to post your code.
_gile
By my side I use home made templates, but if you want use this wizzard, try turning off UAC before installing it.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
