Layer Combobox tool
Layer Combobox tool
Amremad
Message 1 of 13
Layer Combobox tool
Amremad
Hello Every body :
i hope to fine any combox  tool like autocad layer combox tool .. to design my custom layer manger :: can i find it ??
Replies (12)
Message 2 of 13
fieldguy
That looks like a datagridview control with image and text columns.  I can't help with adapting it for the ribbon but there are plenty of posts here on that topic.
Message 3 of 13
FRFR1426
If you can use WPF, there is a way to get a list of layers with their properties (Color, IsOff...) :
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Windows.Data;
namespace MyNameSpace
    public partial class LayerManagerWindow
        public DataItemCollection Layers { get; set; }
        public LayerManagerWindow()
            InitializeComponent();
            Layers = Application.UIBindings.Collections.Layers;
            DataContext = this;
<Window x:Class="MyNameSpace.LayerManagerWindow"
             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
             xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
             xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
             mc:Ignorable="d" d:DesignHeight="300" d:DesignWidth="300">
    <Grid>
        <Grid.RowDefinitions>
            <RowDefinition Height="Auto" />
        </Grid.RowDefinitions>
        <ComboBox ItemsSource="{Binding Layers}">
            <ComboBox.ItemTemplate>
                <DataTemplate>
                    <StackPanel Orientation="Horizontal">
                        <TextBlock Text="{Binding Color}" />
                        <TextBlock Text="{Binding Name}" Margin="7,0,0,0" />
                    </StackPanel>
                </DataTemplate>
            </ComboBox.ItemTemplate>
        </ComboBox>
    </Grid>
</Window>
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
Message 4 of 13
Amremad
sorry i didnt use wpf before .. and i didn't understand your answer
so can you send me the code that working with this way and i will understand it after run it  🙂
Message 5 of 13
FRFR1426
Here is a WinForms version:
DataItemCollection layers = Autodesk.AutoCAD.ApplicationServices.Application.UIBindings.Collections.Layers;
var bs = new BindingSource(layers, null);
comboBox1.DataSource = bs;
comboBox1.DrawMode = DrawMode.OwnerDrawFixed;
comboBox1.DrawItem += (o, args) =>
ICustomTypeDescriptor dataItem = layers[args.Index];
PropertyDescriptorCollection properties = dataItem.GetProperties();
var color = (Autodesk.AutoCAD.Colors.Color) properties["Color"].GetValue(dataItem);
Rectangle bounds = args.Bounds;
int itemHeight = bounds.Height;
Graphics graphics = args.Graphics;
args.DrawBackground();
var rect = new Rectangle(bounds.Left + 1, bounds.Top + 1, itemHeight - 2, itemHeight - 2);
graphics.FillRectangle(new SolidBrush(color.ColorValue), rect);
graphics.DrawRectangle(new Pen(Color.Black), rect);
graphics.DrawString((string) properties["Name"].GetValue(dataItem), args.Font,
new SolidBrush(args.ForeColor), bounds.Left + itemHeight + 6, bounds.Top + 1);
args.DrawFocusRectangle();
Unfortunately, I haven't found a way to sort the layers by their name and I'm running out of time. You should iterate the layer table to construct your list and then sort it.
Maxence DELANNOY
Manager
http://wiip.fr
Message 6 of 13
FRFR1426
I cannot give up so easily, it's stronger than me:
List<ICustomTypeDescriptor> list = layers.OfType<ICustomTypeDescriptor>().ToList();
list.Sort((a, b) => string.Compare(
    ((string) (a.GetProperties()["Name"].GetValue(a))), (string) (b.GetProperties()["Name"].GetValue(b)), StringComparison.CurrentCulture));
comboBox1.DataSource = list;
    ICustomTypeDescriptor dataItem = list[args.Index];
Maxence DELANNOY
Manager
http://wiip.fr
Message 7 of 13
Amremad
thank you very much ..
but i know this way ..   your combobox doesn't have click on every item like autocad combobox .
i need when user click on color rectangle he can choose another color  like autocad combobox . i hope you understand me
so is WPF give what i want ???
Message 8 of 13
FRFR1426
Yes, in WPF it's simpler to make this kind of custom controls. But I cannot explain WPF in a forum thread...
Here is an article on the WPF combobox: http://www.wpf-tutorial.com/list-controls/combobox-control/
You can also make your own control with a popup window like this: http://www.codeproject.com/Articles/27472/ColorComboBox
Maxence DELANNOY
Manager
http://wiip.fr
Message 9 of 13
Amremad
thank you very much
i'm reading now about wpf
Message 10 of 13
FRFR1426
Just found the missing bit for the WinForms solution: http://stackoverflow.com/q/18521110/200443
Maxence DELANNOY
Manager
http://wiip.fr
Message 11 of 13
Amremad
hi again 🙂
i was using  this line
colorPicker1.SelectedIndex = colorPicker1.Items.IndexOf("Yellow");
before using the new combobox ..
no this code doesn't work becouse he search in item text , but the correct must searching in SelectedValue
is there another easy way other than using loop ??
Message 12 of 13
hi,
I would be very happy if you could provide me coding for C# to display the layer and control the layer by windows form application
Message 13 of 13
Mahass
Thank you for this helpful code.
Please can you tell me how to show the layerManagerWindow in the ribbon?
Is it possible to do similar ribboncombo with specific elements (Color, checkbox,Text) for each combo item?
