How to handle Temporary (.ac$) files
eirij
eirij
I have developed a code to slice a solid in specific intervals, and what I have observed that during the process the CIVIL3D creates the Temporary (.ac$) file in temp folder and it keeps increasing its size during the process.
How to control the Temporary file in the code? Is there anything am I missing?
Best Regards,
Eirij
_gile
Have a look at the SAVETIME sysvar.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
eirij
Hi @_gile,
Thank you for your reply, I have tried with the system variable SAVETIME and it didn't work for me, but doing some research on Temporary files I have figured out the problem. Temporary files (.ac$) contain information that is used by various AutoCAD commands (such as UNDO) and this was the reason for creating a huge (.ac$) file in the temp folder while performing the long slicing process.
You can easily enable or disable UNDO recording by
db.DisableUndoRecording(bool disable)
if disable == true UNDO recording is off.
