Change Attribute Tags together
yoitsarun
yoitsarun
I have code to change attribute tag text value. It is working fine.
But i want to change another tag in the same block attribute.
that is , if i change 1st tag then 2nd tag also should be updated automatically.
Is there any way to do that??
using (tr)
                    BlockTableRecord btr =(BlockTableRecord)tr.GetObject(btrId,OpenMode.ForRead);
                    foreach (ObjectId entId in btr)
                        Entity ent =tr.GetObject(entId, OpenMode.ForRead)as Entity;
                        if (ent != null)
                            BlockReference br = ent as BlockReference;
                            if (br != null)
                                BlockTableRecord bd =(BlockTableRecord)tr.GetObject(br.BlockTableRecord,OpenMode.ForRead);
                                if (bd.Name.ToUpper() == blockName)
                                    foreach (ObjectId arId in br.AttributeCollection)
                                        DBObject obj =tr.GetObject(arId,OpenMode.ForRead);
                                        AttributeReference ar =obj as AttributeReference;
                                        if (ar != null)
                                        if (ar.Tag.ToUpper() == attbName)
                                                //if (ar.TextString == "A") then i need to change another Tag
                                            ar.UpgradeOpen();
                                            ar.TextString = "B";
                                            ar.DowngradeOpen();
How i could do this while on another tag? Any suggestions
norman.yuan
You can simply loop through the AttributeCollection twice: the first time, find the first attribute, if found update its value and break the loop. Then you do the loop again to find the second attribute and update it accordingly. Something like:
bool found=false;
foreach (ObjectId id in br.AttributeCollection)
  var att=(AttributeReference)tr.GetObject(id, OpenMode.ForRead);
  if (att.Tag.ToUpper()=="A")
    att.UpgradeOpen();
    att.TextString="xxxxxxx";
    found=true;
    break;
if (found)
    if (att.Tag.ToUpper()=="B")
       '' Update it here
       break;
Or, you can loop through it once to find both attributes and update one or both later:
AttributeReference attA=null;
AttributeReference attB=null;
  if (att.Tag.ToUpper()=="A") attA=att;
  if (att.Tag.ToUpper()=="B") attB=att;
if (attA!=null)
  attA.UpgradeOpen();
  attA.TextString="xxxxxxx";
  if (attB!=null)
    attB.UpgradeOpen();
    attB.TextString="yyyyyy";
HTH
Norman Yuan
Drive CAD With Code
yoitsarun
Thanks Norman,
I will try this.
micle.space
Hi Aruntr
I developed a method for writing the attributes in all blocks of a dwg file.
The new values of attribute's tag are  collected in a dictionary <TAG, Value>
This method searches in all paper spaces (if your dwg file has more then one drawing), for all blocks (but you can specify the name of blocks and enter in the last foreach just for the blocks you need).
Hope this can help you.
public static void WriteAttributes(string fileName, Dictionary<string, string> drawingsData)
	if (!File.Exists(fileName)) return;
	try
		using (var db = OpenSideDatabase(fileName))
			using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
				//all papers
				var dic = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead);
				foreach (DBDictionaryEntry entry in dic)
					//get the layout
					Layout layout = tr.GetObject(entry.Value, OpenMode.ForRead) as Layout;
					//jump if is modelSpace
					if (layout.ModelType) continue;
					BlockTableRecord btr = tr.GetObject(layout.BlockTableRecordId, OpenMode.ForRead) as BlockTableRecord;
					foreach (ObjectId id in btr)
						Entity ent = tr.GetObject(id, OpenMode.ForRead) as Entity;
						if (ent == null) continue;
						if (br == null) continue;
						BlockTableRecord bd = (BlockTableRecord)tr.GetObject(br.BlockTableRecord, OpenMode.ForRead);
							AttributeReference ar = tr.GetObject(arId, OpenMode.ForRead) as AttributeReference;
							if (ar == null) continue;
							ar.UpgradeOpen();
							//instead of switch could be:
							// ar.TextString = drawingsData[ar.Tag];
							// better drawingsData.TryGetValue(...)
							switch (ar.Tag)
								case "TAG1":
									ar.TextString = drawingsData["TAG1"];
									break;
								//other cases
								case....
								default:
									break;
							ar.DowngradeOpen();
			db.SaveAs(fileName, true, DwgVersion.Current, null);
	catch (System.Exception ex)
		//messages...
yoitsarun
Thanks Micle,
i will try this, but my case is different.
I want to change the value of 2nd attribute if the 1st attribute value meets the criteria.
For example if Rev tag is A then i want to change it to B and also need to change the Date tag to the new Date.
I think Norman code is what i was looking for.
micle.space
Norman could hardly be wrong...
