change layer.color and layer.line weight by int and double
i am make function in net autocad using C#
i want change layer.color by int and change layer.lineweight by double
how to do this
 public static ObjectId addlayer(string namalayer,double lineweight,int color)
            var doc = app.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            ObjectId idx = db.LayerTableId;
            using (Transaction acTrans = db.TransactionManager.StartTransaction())
                LayerTable acLyrTbl;
                acLyrTbl = acTrans.GetObject(db.LayerTableId,OpenMode.ForRead) as LayerTable;
                if (acLyrTbl.Has(namalayer) == false)
                    LayerTableRecord acLyrTblRec = new LayerTableRecord();
                    acLyrTblRec.Color = Color.FromColorIndex(ColorMethod.ByColor, color);
                    acLyrTblRec.LineWeight = lineweight;
                    acLyrTblRec.Name = namalayer;
                    acLyrTbl.UpgradeOpen();
                    idx= acLyrTbl.Add(acLyrTblRec);acTrans.AddNewlyCreatedDBObject(acLyrTblRec, true);
                    db.Clayer = idx;
                else
                    db.Clayer = acLyrTbl[namalayer];
                acTrans.Commit();
                return idx;
_gile
About color, to pass an integer as color index, you have to use the ColorMethod.ByAci.
About line weight, you have to use a member of the LineWeight enumeration or its corresponding integer.
public static ObjectId AddLayer(string name, double lineweight, int color)
    ObjectId idx;
    using (Transaction tr = db.TransactionManager.StartTransaction())
        var layerTable = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead);
        if (layerTable.Has(name))
            idx = layerTable[name];
        else
            var layer = new LayerTableRecord();
            layer.Color = Color.FromColorIndex(ColorMethod.ByAci, (short)color);
            try { layer.LineWeight = (LineWeight)(int)(lineweight * 100); }
            catch { layer.LineWeight = LineWeight.ByLayer; }
            layer.Name = name;
            layerTable.UpgradeOpen();
            idx = layerTable.Add(layer);
            tr.AddNewlyCreatedDBObject(layer, true);
            db.Clayer = idx;
        tr.Commit();
        return idx;
Gilles Chanteau
GileCAD
GitHub
@_gile  i has try
Objectid idx; (but while compile allert idx unlocal variable) how to fix
_gile
@Anonymous  a écrit :
@_gile  i has try
Sorry but I do not understand what you mean. The code I posted works as expected here.
Either you copy the whole code or you only adapt the Color and LineWeight expressions to your code.
Gilles Chanteau
GileCAD
GitHub
@_gile  thankyou work like charm
