Existing selected viewport
carlosrdrzalns
carlosrdrzalns
In a part of my current command i need to select a viewport to get te points of it, tramsform them to the model space an select all entities within the viewport area. The problem is that when i selected this viewport, the program get me inside of it and i don't know how to exist it.
after that, commnads like Editor.SwitchtoModelSpace() does not work.
I tried disposing the viewport or with using but neither they works.
Could somebody help me with this problem?
Probably it is trivial but I can't found the key of the problem.
My code is as follows:
 Dim opt As PromptEntityOptions = New PromptEntityOptions("Pick a Viewport")
                opt.SetRejectMessage("object must be a viewport")
                opt.AddAllowedClass(GetType(Viewport), True)
                Dim per As PromptEntityResult = ed.GetEntity(opt)
                If per.Status <> PromptStatus.OK Then
                    ed.WriteMessage("Error intentando obtener el objeto seleccionado. Saliendo de la función.")
                    Return
                Dim PSVPpoints As Point3dCollection = New Point3dCollection
                Dim MSVPpoints As Point3dCollection = New Point3dCollection
                Using VP As Viewport = tr.GetObject(per.ObjectId, OpenMode.ForRead)
                    ed.WriteMessage("El número de puntos antes de obtener los de la viewport son {0}" + vbCrLf, PSVPpoints.Count)
                    VP.GetGripPoints(PSVPpoints, New IntegerCollection(), New IntegerCollection())
                    ed.WriteMessage("El número de puntos en la coleccion es : {0}" + vbCrLf, PSVPpoints.Count)
                    Dim tpm As Point3d = PSVPpoints(2)
                    PSVPpoints(2) = PSVPpoints(1)
                    PSVPpoints(1) = tpm
                    PSVPpoints.Remove(PSVPpoints(PSVPpoints.Count - 1))
                    Dim PSDSC2UCS = PSDCS2DCS(VP) * DCS2WCS(VP) * ed.CurrentUserCoordinateSystem
                    For Each pnt As Point3d In PSVPpoints
                        Dim point As Point3d
                        point = pnt.TransformBy(PSDSC2UCS)
                        MSVPpoints.Add(point)
                        ed.WriteMessage("Punto en PS: {0}   Punto en MS: {1}" + vbCrLf, pnt, point)
                    Next
                End Using
                ed.WriteMessage("tenemos {0} puntos transladados al model space" + vbCrLf, MSVPpoints.Count)
                ed.SwitchToModelSpace()
                ed.WriteMessage("he cambiado al model space")
                Dim acTypValAr(1) As TypedValue
                acTypValAr.SetValue(New TypedValue(DxfCode.LayerName, "SE-Zz_2-E"), 0)
                acTypValAr.SetValue(New TypedValue(DxfCode.Start, "MTEXT"), 1)
                Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr)
                Dim SelectionResult As PromptSelectionResult = ed.SelectCrossingPolygon(MSVPpoints, acSelFtr)
                If SelectionResult.Status <> PromptStatus.OK Then
                    Return
                Dim SelectSet As SelectionSet = SelectionResult.Value
                ed.WriteMessage("hemos seleccionado {0} entidades" + vbCrLf, SelectSet.Count)
Please, ignore all "ed.Writemessage()" as they are used for debbuging.
mujibur.rahman
after this line of code  ed.SwitchToModelSpace()'  you will enter in the model space
you trying to select some objects using selection filter..,
if you want to return to paper space just pass the command '  ed.SwitchToPaperSpace()'
you can also pass command 'CHSPACE' by command method to return to paper space..
carlosrdrzalns
Thank you @mujibur.rahman it works!
i thought that ed.SwithcToModelSpace will change to the model Space tab instead of entering the viewport.
Kind regards.
