how to fill color inside a Closed polyline (Rectangle) in .net C#
不适用
2,025 次查看
3 条回复
1 条消息(共 4 条)
不适用
Hi ,
I am creating a rectangle with below code.I have set a color as well for the line.But instead of that,I want to fill the inside of rectangle with a color .Is it possible to do from C#.please help
 double[]  coordinate = GlobalVariable.stringToDoubleArray(areapoints, ',');
//create polyline
polylineObject = null;
polylineObject = acadDocument.ModelSpace.AddPolyline(coordinate);
if (polylineObject != null)
polylineObject.Closed = true;
polylineObject.color = (ACAD_COLOR)GlobalVariable.colorDictionary[(parameter.GetElementColor().ToString())];
polylineObject.Linetype = GlobalVariable.lineTypeDictionary[lineTypeName[0].ToString().ToUpper()];
Thanks in advance,
Anu
0 个赞
已接受的解答 (2)
2,026 次查看
3 条回复
回复 (3)
2 条消息(共 4 条)
vkpunique
已接受的解答
Hi anupaman, you need to use Hatch object.
Follow this reference : AutoCAD .NET Developer's Guide: Edit Hatch Patterns (autodesk.com)
0 个赞
3 条消息(共 4 条)
不适用
Thanks,I will check .can you please tell me which namespace does this belong to or the dll I have to refer.Mine is Autodesk 2020.
0 个赞
4 条消息(共 4 条)
不适用
已接受的解答
You can ignore this , I could get the AcadHatch from Interop.AutoCAD dll ..Thanks once again
0 个赞
