Opening multiple prompts simultaneously
Hi all - I'm looking for a way to prompt a user for an arbitrarily long sequence of selection sets, only stopping when they type in a particular command. This seems like it would require both a StringResult and a SelectionResult object to be open at the same time, which I'm not sure is possible. Any advice would be much appreciated 🙂
Tyler
norman.yuan
No sure I understand you correctly, but here it goes:
You place the call to EditorGetSelection()  in a Loop, with each round selecting is done, you can as user to continue or not, something like
var selectedEnts=new List<ObjectId>();
while(true)
    var opt=new PromptSelectionOption(...);
    var filter = new SelectionFilter(...)
    var res = ed.GetSelection(filter, opt);
    if (res.Status == PromptStatus.OK)
        selectedEnts.AddRange(res.Value.GetOjectIds());
        var kOpt=new PromptKeywordOption(...);
        kOpt.Keywords.Add(...);
        var kRes=ed.HetKeyword(kOpt);
        if (kRes.Status == PromptStatus.OK)
           '' based on user's keyword input, decide to do another round selection or not
        else
            break;
    else
        break;
Instead of getting user input after each round selection with Editor.GetKeyword(), you probably can use PromptSelectionOption.Keyword and handle its KeywordInput/UnknownInput events to decide whether you want to do another round selection or not.
Norman Yuan
Drive CAD With Code
